Cannot lock channels on specific MUX
Postby eugeno » Fri Jan 20, 2023 6:32 pm
I've been using my TBS6281SE for over a year, but several days ago all channels from one MUX stopped working. No updates have been installed recently, I didn't even restart the server (the card is plugged into HP Microserver Gen10 Plus). This MUX is working well from the same cable on my TV, so it is not related to the signal.
Tvheadend just cannot scan this MUX, no services can be found. The same with w_scan_cpp. I've tried to lock the frequency with dvblast and here is the result:
$ dvblast -f 650000000 -b 8 -a 0 -5 dvbt2 -vvv
DVBlast 3.4 (release)
warning: restarting
debug: compiled with DVB API version 5.11
debug: using DVB API version 5.11
debug: Frontend "TurboSight TBS 6281SE DVB-T/T2/C " supports:
debug:  frequency min: 48000000, max: 870000000, stepsize: 62500, tolerance: 0
debug:  symbolrate min: 1000000, max: 7200000, tolerance: 0
debug:  capabilities:
debug:   INVERSION_AUTO
debug:   FEC_1_2
debug:   FEC_2_3
debug:   FEC_3_4
debug:   FEC_5_6
debug:   FEC_7_8
debug:   FEC_AUTO
debug:   QPSK
debug:   QAM_16
debug:   QAM_32
debug:   QAM_64
debug:   QAM_128
debug:   QAM_256
debug:   QAM_AUTO
debug:   TRANSMISSION_MODE_AUTO
debug:   GUARD_INTERVAL_AUTO
debug:   HIERARCHY_AUTO
debug:   2G_MODULATION
debug:   MULTISTREAM
debug:   FE_CAN_MUTE_TS
debug:  delivery systems:
debug:   DVBT
debug:   DVBT2
debug:   DVBC_ANNEX_A
debug:   DVBC_ANNEX_B
debug: tuning DVB-T2 frontend to f=650000000 bandwidth=8 inversion=-1 fec_hp=999 fec_lp=999 hierarchy=-1 modulation=qam_auto guard=-1 transmission=-1 PLP_ID=0
warning: failed opening CAM device /dev/dvb/adapter0/ca0 (No such file or directory)
debug: setting filter on PID 0
debug: setting filter on PID 16
debug: setting filter on PID 17
debug: setting filter on PID 18
debug: setting filter on PID 19
debug: setting filter on PID 20
error: no config file
debug: frontend has acquired signal
debug: frontend has acquired carrier
And it hangs at this forever. Quite strange.
Can it be a hardware issue? The warranty has not expired yet, but I'd like to make sure first that it is not related to the setup. Unfortunately, I don't have another device with PCIe slot to test the card.
eugeno
Re: Cannot lock channels on specific MUX
Postby zhangchao » Fri Feb 03, 2023 3:08 pm
hi ,
please add skype jack_2431 . i will check with you .
best regards!
zhangchao
Postby eugeno » Tue Feb 14, 2023 4:07 pm
The issue has been resolved. The card is working, it was the antenna that caused low signal on a mux. My TV was receiving the signal because it has probably more sensitive adapter. I reported this to the home management and they fixed the antenna. Thank you zhangchao for your help!
eugeno
Return to PCIe DVB-T2/T/C Dual Tuner Card TBS6281SE
