i2c i2c-1 stid135_probe :fe_stdid135_init error 13
Postby nborjas » Fri Oct 28, 2022 8:44 am
Hello Good morning, I have a problem, I can't install the TBS drivers of the 6909 X2 on a dell 320 server, I get an error like the one attached, can someone help me please.
errordriver.docx
Foto del error en el servidor al arrancar
(194.48 KiB) Downloaded 481 times
nborjas
Re: i2c i2c-1 stid135_probe :fe_stdid135_init error 13
Postby smile » Mon Oct 31, 2022 10:26 am
Hi sir
the error show the card's i2c error, cannot communicate with the chip.
Do you have try it with other pc? is it working?
Best Regards
smile
Postby nborjas » Wed Nov 02, 2022 12:25 am
We will not try it on another PC yet, I tell you.
Thank you very much.
nborjas
Postby nborjas » Wed Nov 02, 2022 1:27 am
Hello, it was installed on another server and it comes out the same, it recognizes the card but it throws the same error.
if you look recognize the card.
01:00.0 Multimedia controller: TBS Technologies DVB-S2 4 Tuner PCIe Card
nborjas
Postby smile » Wed Nov 02, 2022 9:41 am
Could you try this way:
ctreat a config file<tbsecp3.conf> on /ect/modprobe.d
input: options tbsecp3 enable_msi=0
save it , then reboot the server.
Best Regards
smile
Return to News
