Can't Install 6902 Drivers on Windows 8.1
Postby clevoir » Mon Sep 12, 2022 2:50 am
I had a TBS6981 card fail on me, and replaced with a TBS6902 card instead
I am running Windows 8.1 Pro x64, and when I tried to install the drivers Windows reports that the device is not supported on the platform.
I have tried using latest drivers 10.0.5, 1.0.0.3 and 1.0.0.2 too. All give the same result, installing in safe mode has no effect either.
I would appreciate any help, I thought that this card was compatible with Windows 8.1????
clevoir
Re: Can't Install 6902 Drivers on Windows 8.1
Postby smile » Tue Sep 13, 2022 10:57 am
Could you show me the error ?
is it the drivers signature problem?
Best Regards
smile
Postby clevoir » Thu Sep 15, 2022 4:07 am
I have given up and will be returning to Amazon for a refund.
I have now bought a 2nd hard TBS6982 card and it works fine with W7 drivers
clevoir
Postby crazycat » Thu Sep 15, 2022 10:12 pm
6902 win x64 driver signed only for Win10 WHQL.
need vendor-signed driver for Win vista + (6.0+)
