Can't get DiSEqC from TBS6504 to work in linux
TBS6504 is a Quad PCI express TV tuner card that supports multiple digital TV standards including DVB-S2X/S2/S/T2/T/C2/C/ISDB-T.
Postby bobben » Thu Apr 21, 2022 3:55 am
My TBS6504 card does seem to have a problem with DiSEqC 1.0 (linux ubuntu 20.04). I am using this guide for driver installation https://github.com/tbsdtv/linux_media/wiki
Have tried several different brand DiSEqC 1.0 switches but it does not help.
I have also a TBS6903 and TBS6908 that works well with my DiSEqC 1.0 switches but I would really like to use DiSEqC in TBS6504.
Did use dvblast and tsduck to test DiSEqC switching but still no success with TBS6504.
Any suggestions for solutions would be appriciated.
bobben
Re: Can't get DiSEqC from TBS6504 to work in linux
Postby smile » Mon Apr 25, 2022 11:20 am
Could you show me the ''demsg'' info?
Best regards
smile
Postby bobben » Mon Apr 25, 2022 5:22 pm
Be aware that the TBS6504 drivers seems to be successfully installed. Card works well with all inputs and for both DVB-T and DVB-S/S2 and has been working for a few years but the desire to use diseqc switch has not been there until now. It is only the diseqc part that will not control my diseqc switches ( tested three different diseqc 1.0 four port switches).
I have run dmesg | grep 'TBS':
[   10.518473] TBSECP3 driver 0000:01:00.0: TurboSight TBS 6504 DVB-S/S2/S2X/T/T2/C/C2/ISDB-T
[   10.519036] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[   10.641693] TBSECP3 driver 0000:01:00.0: MAC address ff:ff:ff:ff:ff:ff
[   13.033082] TBSECP3 driver 0000:01:00.0: DVB: registering adapter 0 frontend 0 (TurboSight TBS 6504 DVB-S/S2/S2X/T/T2/C/C2/ISDB-T )...
[   13.033121] TBSECP3 driver 0000:01:00.0: DVB: registering adapter 0 frontend 1 (TurboSight TBS 6504 DVB-S/S2/S2X/T/T2/C/C2/ISDB-T )...
[   13.033149] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[   13.121643] TBSECP3 driver 0000:01:00.0: MAC address ff:ff:ff:ff:ff:ff
[   13.128512] TBSECP3 driver 0000:01:00.0: DVB: registering adapter 1 frontend 0 (TurboSight TBS 6504 DVB-S/S2/S2X/T/T2/C/C2/ISDB-T )...
[   13.128541] TBSECP3 driver 0000:01:00.0: DVB: registering adapter 1 frontend 1 (TurboSight TBS 6504 DVB-S/S2/S2X/T/T2/C/C2/ISDB-T )...
[   13.128563] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[   13.249525] TBSECP3 driver 0000:01:00.0: MAC address ff:ff:ff:ff:ff:ff
[   13.256535] TBSECP3 driver 0000:01:00.0: DVB: registering adapter 2 frontend 0 (TurboSight TBS 6504 DVB-S/S2/S2X/T/T2/C/C2/ISDB-T )...
[   13.256569] TBSECP3 driver 0000:01:00.0: DVB: registering adapter 2 frontend 1 (TurboSight TBS 6504 DVB-S/S2/S2X/T/T2/C/C2/ISDB-T )...
[   13.256589] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[   13.377623] TBSECP3 driver 0000:01:00.0: MAC address ff:ff:ff:ff:ff:ff
[   13.384502] TBSECP3 driver 0000:01:00.0: DVB: registering adapter 3 frontend 0 (TurboSight TBS 6504 DVB-S/S2/S2X/T/T2/C/C2/ISDB-T )...
[   13.384534] TBSECP3 driver 0000:01:00.0: DVB: registering adapter 3 frontend 1 (TurboSight TBS 6504 DVB-S/S2/S2X/T/T2/C/C2/ISDB-T )...
[   13.384556] TBSECP3 driver 0000:01:00.0: TurboSight TBS 6504 DVB-S/S2/S2X/T/T2/C/C2/ISDB-T : PCI 0000:01:00.0, IRQ 33, MMIO 0xf7e00000
[   13.384658] TBSECP3 driver 0000:03:00.0: TurboSight TBS 6903 DVB-S/S2
[   13.384967] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[   13.505683] TBSECP3 driver 0000:03:00.0: MAC address 00:22:..............
[   14.052135] TBSECP3 driver 0000:03:00.0: DVB: registering adapter 4 frontend 0 (TurboSight TBS 6903 DVB-S/S2 )...
[   14.052260] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[   14.152534] TBSECP3 driver 0000:03:00.0: MAC address 00:22:..............
[   14.152550] TBSECP3 driver 0000:03:00.0: DVB: registering adapter 5 frontend 0 (TurboSight TBS 6903 DVB-S/S2 )...
[   14.152620] TBSECP3 driver 0000:03:00.0: TurboSight TBS 6903 DVB-S/S2 : PCI 0000:03:00.0, IRQ 35, MMIO 0xf7d00000
[   14.152742] TBSECP3 driver 0000:06:00.0: TurboSight TBS 6908 DVB-S/S2
[   14.153142] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[   14.276304] TBSECP3 driver 0000:06:00.0: MAC address 00:22:..............
[   14.309354] TBSECP3 driver 0000:06:00.0: DVB: registering adapter 6 frontend 0 (TurboSight TBS 6908 DVB-S/S2 )...
[   14.309429] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[   14.415428] TBSECP3 driver 0000:06:00.0: MAC address 00:22:..............
[   14.415439] TBSECP3 driver 0000:06:00.0: DVB: registering adapter 7 frontend 0 (TurboSight TBS 6908 DVB-S/S2 )...
[   14.415575] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[   14.537592] TBSECP3 driver 0000:06:00.0: MAC address 00:22:..............
[   14.570189] TBSECP3 driver 0000:06:00.0: DVB: registering adapter 8 frontend 0 (TurboSight TBS 6908 DVB-S/S2 )...
[   14.570248] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[   14.689591] TBSECP3 driver 0000:06:00.0: MAC address 00:22:..............
[   14.689601] TBSECP3 driver 0000:06:00.0: DVB: registering adapter 9 frontend 0 (TurboSight TBS 6908 DVB-S/S2 )...
[   14.689675] TBSECP3 driver 0000:06:00.0: TurboSight TBS 6908 DVB-S/S2 : PCI 0000:06:00.0, IRQ 36, MMIO 0xf7c00000
bobben
Postby smile » Fri May 06, 2022 10:36 am
Could you set the remote control for us?
send the email to me (Davin@tbsdtv.com or support@tbsdtv.com)
smile
Postby bobben » Wed May 11, 2022 5:22 pm
The TBS6504 card also behaves strange in Windows10. Can not get diseqc to work. Maybe
there is a failed component.
I have swapped around my TBS demodulator cards and use a different card with the diseqc switch. I prefer not to use more time/attempts to get diseqc working on my TBS6504.
bobben
Return to TBS6504 Multi Standard Quad Tuner PCI-e Card
