TBS6590 What cam to use?
Postby Bean85 » Thu Feb 24, 2022 6:00 pm
Hi!
I just have bought me this TV card with 2 CI slots my question is do any of you know what cam that is supported?
i live in Sweden and i just tested a TV provider "Boxer" so i got i CI module from the provider but DVBViewer/TBSV/DVBDream dont even recognise the module and the programs crashes.
i use Windows 11
TBS 6590 (((T/T2)))
CI Module from TV provider.
https://www.netonnet.se/art/tv/tv-tillb ... sQAvD_BwE#
I know that TBS card dont support CI+ but what i have learned is "CI+" is back compatible with ordinarie "CI".
By the way is there any TBS card that support CI+?
And i have tried all of those TBSclapi.dll "No one worked"
Do any of you have more information about what to do?
Is there any in Europe/Nordic countrys who can use this card with CI and watch pay channels?
I can get the free channels with no probs...
Regards Daniel
Bean85
Re: TBS6590 What cam to use?
Postby DVB » Fri Feb 25, 2022 8:27 am
Bean85 Wrote:I know that TBS card dont support CI+ but what i have learned is "CI+" is back compatible with ordinarie "CI".
Only if operator allows that mode. In most cases operator do not allow this, it's rather a rare case, but I'm not aware how it looks like for Boxer service.
Bean85 Wrote:By the way is there any TBS card that support CI+?
Under Windows - no. CI+ has got a strict licencing rules which cannot be fullfilled legally basically for anything on PC. But there were attempts to do something for Linux (unlicensed).
And now you're watching 8K:
KKKKKKKK
DVB
Postby Bean85 » Fri Feb 25, 2022 6:18 pm
Thanks for that info
you learn more and more :)
Thinking of getting a satallite system instead of (T/T2) with this card and switch to a linux distrubution.
Maybe i have a better luck there.
From what i have read about Cams and this card the
"Conax" kind is a better choice.
Bean85
