Win 10 Unsigned Driver issue
Postby meowmeow » Tue Jan 11, 2022 4:15 pm
After I solved the Win 10 Code 39 issue thanks to the forum the next problem appeared. As the drivers are apparently unsigned Win10 can only install und use it if you temporarily disable this "integrity check". (Advanced boot menu etc). Then the card works, BUT ONLY UNTIL NEXT REBOOT ! You cannot permanently disable this check. And honestly I am not willing to disable all security features provided by MS just to run a card with poor drivers.
I dont unterstand why this is so hard for TBS to provide signed drivers like any other HW manufacturer...
How did all other Win10 users solve this issue? How did you get the card to work?
Marc
meowmeow
Re: Win 10 Unsigned Driver issue
Postby DVB » Tue Jan 11, 2022 8:40 pm
Which card model? TBS drivers from tbsdtv.com are signed, so you're using some test release drivers or something.
And now you're watching 8K:
KKKKKKKK
DVB
Postby meowmeow » Wed Jan 12, 2022 9:46 pm
My card is TBS 6922 TE.
I used the drivers from tbsdtv.com (V1.0.1.5.) as well as tbs-technology.de (V 1.0.0.3) , none of them worked was accepted as "signed"
meowmeow
Postby DVB » Thu Jan 13, 2022 1:22 am
Are you absolutely sure that you've got "6922TE" version? That's very important, because there was also "6922SE" version and it's not the same device.
1.0.1.5 drivers are incorrect for TE, they're for SE. 1.0.0.3 are old drivers for TE.
All mentioned drivers are signed - check .cat file - signature is present, but sha1 only, as this is old (ancient) device.
If you've got 6922TE, try to use this driver.
https://www.tbsiptv.com/download/tbs690 ... .0.0.5.zip
Don't pay attention, that archive says 6902 - it's fine, as there's information here, that 6922TE driver is same as for 6902.
If you would like to use up to date hardware, DVB card hardware also has to be up to date.
KKKKKKKK
DVB
Postby meowmeow » Thu Jan 13, 2022 3:22 pm
Yes it is the TE hardware, I looked again. I will try it again now.
Marc
meowmeow
Postby meowmeow » Thu Jan 13, 2022 4:59 pm
Its working now. With the drivers you provided in the link. THANK YOU!!
meowmeow
