kernel Linux 5.15.13-051513-generic
Postby mesonic1 » Mon Jan 10, 2022 5:06 am
I have Ubuntu 20.04.3 LTS (GNU/Linux 5.15.13-051513-generic x86_64)
after build and install, dmesg | grep frontend show nothing
tested many media_build package and all compilation errors
thanks
mesonic1
Re: kernel Linux 5.15.13-051513-generic
Postby steven » Fri Jan 14, 2022 10:13 am
Hi Sir
which driver you are using you can have a try with this package :
#wget https://www.tbsdtv.com/download/document/linux/media_build-2022-01-07.tar.bz2
#tar jxvf media_build-2022-01-07.tar.bz2
#cd media_build
#./install.sh
#reboot
Postby zhangchao » Fri Jan 14, 2022 10:15 am
hi ,
follow the steps . if also has issue ,add skype jack_2431.
cd media_build
make dir DIR=../media
make allyesconfig
make -j4
sudo make install
reboot
best regards!
zhangchao
Return to DVB-S2 Quad Tuner PCIe Card TBS6904
