loosing drivers after restart
Postby e4glenight » Thu Dec 30, 2021 2:25 am
I have one TBS6209 in a Ubuntu server. I use closed driver. When I install it, i can see it on TvHeadEnd. but if my machine restart or loose power, i loose drivers and i have to reinstall it for making this working...
i follow the readme file :
# wget http://www.tbsdtv.com/download/document ... 25.tar.bz2
# tar jxvf media_build-2021-08-25.tar.bz2
# cd media_build
#./install.sh
# reboot [/code]
After reboot, i have TBS6209 visible on TvHeadEnd
Here what i get in uname dmesg and lspci
tbs@tbs:~$ uname -a
Linux tbs 5.11.0-43-generic #47~20.04.2-Ubuntu SMP Mon Dec 13 11:06:56 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
dmesg and lspci are in pdf (can't post here, too many characters and i can't attach txt files)
lspci.pdf
lspci
(54.67 KiB) Downloaded 362 times
dmesg.pdf
(84.93 KiB) Downloaded 361 times
and right now, i can use TVHeadEnd for watching TV. but if i restart or my server loosing power, i have to reinstall drivers...
Tell me if you want some add information :)
Thanks for help,
Stephane
e4glenight
Re: loosing drivers after restart
Postby steven » Thu Dec 30, 2021 9:46 am
Hi Sir
Please check after reboot the kernel whether updated if you are using ubuntu please disable the kernel auto update with this:
#apt-mark hold linux-image-generic linux-headers-generic
thanks
kind Regards
Postby e4glenight » Sun Jan 02, 2022 8:05 pm
hello !
Its works :)
Thanks for help,
Stéphane
e4glenight
Return to TV Signal Cable Connection and Mode Selection
