Need fixes for TBS5930
2021 New Arrival! digital satellite external TV tuner box TBS5930 DVB-S/S2/S2X TV Tuner USB card.
Postby alonsosjumper » Tue Dec 14, 2021 5:24 pm
Hi, i´ve recently purchased the TBS 5930 usb tuner, and it doesn´t work properly with the latest driver (1.0.0.4).
The higher frequencies don´t appear, blindscan not working, ebspro and crazycan neither...
Please solve these bugs or i´ll have to return it.
alonsosjumper
Re: Need fixes for TBS5930
Postby DVB » Sun May 08, 2022 8:42 am
Does anybody knows how that ended?
Driver is still 1.0.0.4.
There was a known issue with I2C calls, well described here: https://sourceforge.net/p/crazyscan/dis ... de420eb5d/
Crashes are still reported, eg. http://ebspro.net/blog/ebspro-v18-0-0-1 ... 5849130346
Is there any beta driver, which fixes that?
And now you're watching 8K:
KKKKKKKK
DVB
Postby crazycat » Mon May 09, 2022 1:28 am
Not fixed yet
Postby DVB » Fri May 20, 2022 4:59 am
@steven - any chances for new drivers release for 5930 with fix for freeze when loading in StreamReaderEx-BDA (CrazyScan)?
Crash (freeze) with CrazyScan confirmed here on drivers v1.0.0.4 and v1.0.0.3.
On v1.0.0.2 card is not freezed on the start of CrazyScan, but does not work - RFScan is flat, BlindScan finds nothing.
Card itself looks interesting, even got some partial signal from ACM/VCM freqs, so there's a chance that card would be able to detect them.
Lock is pretty fast, scanning - reliable, stability of reception - decent (no dropouts/missing packets for a longer period of monitoring). Not heating too much.
If blindscan would work reliable too, then who knows, maybe it would be a gap filler between 5927 without DVB-S2X and 5520SE, which is unable to receive some transmissions?
Unfortunately missing blindscan is a dealbreaker right now.
PS
@crazycat - checked also your debug drivers in test mode - issue also present there + high count of missing packets (just to confirm).
KKKKKKKK
DVB
Postby DVB » Fri May 27, 2022 4:23 am
Bump :)
Description: https://www.tbsdtv.com/products/tbs5930 ... -card.html says it's blindscan capable, HW surely is, because it's based on M88RS6060, like 6902SE. But because of faulty drivers there's no software which can do blindscan right now on 5930. A small drivers fix for 5930 to resolve this would be appreciated ;)
KKKKKKKK
DVB
Postby crazycat » Fri May 27, 2022 9:46 pm
i can't fix driver without device
Postby DVB » Sat May 28, 2022 1:37 am
I meant rather TBS ;) You did already more than anybody else ever, with great CrazyScan and StreamReaderEx-BDA :) Thanks to you the whole DVB cards world is today in a totally different place. I really doubt that we would watch PLS or MIS so easily or we would have so powerfull blindscan without your contributions. Pretty much a glorious thing!
Additionally I don't want to bother you too much, there's a lot of bad things going on in Ukraine right now... Hope that you are safe.
But... I can probably provide you 5930 if you would like to put your hands on it ;) Please let me know if I should get one for you. Without any expectations to fix anything - just if you would like to play a bit with this one ;)
5930 is nice device IMHO with chances to be a decent HW... if TBS will fix the drivers :mrgreen:
@steven, where are you? Please fix the drivers for 5930 ;)
KKKKKKKK
DVB
Postby smile » Tue May 31, 2022 2:48 pm
Could you set the remote access for us to check the problem?
if you use the win10 , please disable the drivers signature to easy to debug the drivers.
please emali to Davin@tbsdtv.com or support@tbsdtv.com
Best Regards
smile
Postby DVB » Sun Dec 04, 2022 10:13 am
Drivers update is planned? We had some live sessions at June & July, but finally the whole work seems to went up in the smoke :cry:
KKKKKKKK
DVB
Postby EnoSat » Sat Dec 10, 2022 12:55 am
it seems that DVB cards are already on the "side track" :cry:
EnoSat
Return to DVB-S2X/S2 TV Tuner USB Card TBS5930
