Ubuntu 20.04.3 Kerel 9.4.0-90 TBS6205 & 6902 Fails
Postby noz1381 » Thu Nov 18, 2021 3:01 am
Hi everyone.
Ive been running these 2 cards in a headless ubuntu server for a few years.
Thro hardware failure I have rebuilt the server with 20.04.3
When I follow the tut here https://github.com/tbsdtv/linux_media/wiki my build starts with fails on the "make allyesconfig" command:
WARNING: This is the V4L/DVB backport tree, with experimental drivers
         backported to run on legacy kernels from the development tree at:
                http://git.linuxtv.org/media-tree.git.
         It is generally safe to use it for testing a new driver or
         feature, but its usage on production environments is risky.
         Don't use it in production. You've been warned.
CEC_CROS_EC: Requires at least kernel 9.255.255
V4L2_H264: Requires at least kernel 9.255.255
VIDEO_IPU3_CIO2: Requires at least kernel 9.255.255
VIDEO_OMAP3: Requires at least kernel 9.255.255
VIDEO_ROCKCHIP_ISP1: Requires at least kernel 9.255.255
VIDEO_IMX258: Requires at least kernel 9.255.255
VIDEO_IMX274: Requires at least kernel 9.255.255
VIDEO_OV02A10: Requires at least kernel 9.255.255
VIDEO_OV772X: Requires at least kernel 9.255.255
VIDEO_OV9650: Requires at least kernel 9.255.255
SND_BT87X: Requires at least kernel 9.255.255
INTEL_ATOMISP: Requires at least kernel 9.255.255
VIDEO_HANTRO: Requires at least kernel 9.255.255
VIDEO_ROCKCHIP_VDEC: Requires at least kernel 9.255.255
VIDEO_IPU3_IMGU: Requires at least kernel 9.255.255
./scripts/fix_kconfig.pl
make[1]: Leaving directory '/home/mark/tbsdrivers/media_build/v4l'
mark@steve30:~/tbsdrivers/media_build$
I'm unsure on the issue as previously this has worked like a charm.
BTW no unbuntu specialist, I just manage to get by and get up this media server.
Thanks for your help.
noz1381
Re: Ubuntu 20.04.3 Kerel 9.4.0-90 TBS6205 & 6902 Fails
Postby zhangchao » Thu Nov 18, 2021 11:08 am
hi,
you can use "make -j4" to compile .
this warning is not issue .
best regards !
zhangchao
Postby noz1381 » Thu Nov 18, 2021 3:04 pm
I get errors at that stage too.
I see errors fly past, but when I go to copy the output, I cannot select all the text, it only gives me a section.
noz1381
Postby zhangchao » Mon Nov 22, 2021 9:55 am
hi ,
please add skype jack_2431. or set anydesk i will check .
best regards!
zhangchao
Postby noz1381 » Mon Oct 17, 2022 3:12 pm
zhangchao Wrote:hi ,
best regards!
Hi, I wondered if you still might assist? Tried again just recently, and I cant get the drivers to install.
You help would be super, thank you.
noz1381
