How To Fix Windows10 Cursor Glitch Issue?
Postby Curtisestep3 » Fri Jun 04, 2021 4:10 pm
Hello friends. This is my first post in this forum. For the past few days, I have been suffering from Glitch problems with my computer's cursor. I don’t know why this is happening, and how to fix this issue. I am using Windows10. Can anyone provide any suggestions for this issue? Any help will be appreciated.
Curtisestep3
Re: How To Fix Windows10 Cursor Glitch Issue?
Postby steven » Mon Jun 07, 2021 10:42 am
Hi Sir
Which tuner card you are using ? and what about the signal is it ok ?
Postby Curtisestep3 » Mon Jun 07, 2021 1:20 pm
Click to view report Click to view report
Thanks for replying. I found this article by searching Google yesterday. I have solved the problem by following that. There was a problem with the GPU driver. It has been resolved after updating.
Curtisestep3
Return to Off topics
