tbs-open-linux-driver swipes Ubuntu 20.04 graphics driver
Postby hsmptg » Sun Apr 11, 2021 7:14 pm
I was trying to install the driver of a TBS6982 on a fresh Ubuntu 20.04 (kernel 5.8.0-48-generic) running on a PC having a i7-4790K CPU with Intel Integrated Graphics Controller (i915).
I used the TBS Open Source Linux Driver Offline Package v20210204 and in the end I had success:
helio@hercules:~$ dmesg | grep frontend
[    2.985229] SAA716x Budget 0000:03:00.0: DVB: registering adapter 0 frontend 0 (TurboSight TBS 6982SE DVB-S/S2)...
[    3.291713] SAA716x Budget 0000:03:00.0: DVB: registering adapter 1 frontend 0 (TurboSight TBS 6982SE DVB-S/S2)...
I confirmed that the driver was working, since it is recognised on a TVHeadend server I installed next.
The problem is that prior to the driver installation I had a fully functioning graphics driver as can be seen on the following commands:
helio@hercules:~$ inxi -G --display
Graphics:
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
  driver: i915 v: kernel
  Display: server: X.Org 1.20.9 driver: i915 resolution: 1920x1080~60Hz
  OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2)
  v: 4.5 Mesa 20.2.6
helio@hercules:~$ sudo lshw -C video
  *-display
       description: VGA compatible controller
       product: Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller
       vendor: Intel Corporation
       physical id: 2
       bus info: pci@0000:00:02.0
       version: 06
       width: 64 bits
       clock: 33MHz
       capabilities: msi pm vga_controller bus_master cap_list rom
       configuration: driver=i915 latency=0
       resources: irq:33 memory:f7800000-f7bfffff memory:e0000000-efffffff ioport:f000(size=64) memory:c0000-dffff
helio@hercules:~$ lsmod | grep i915
i915                 2195456  10
drm_kms_helper        217088  1 i915
cec                    53248  2 drm_kms_helper,i915
i2c_algo_bit           16384  1 i915
drm                   552960  5 drm_kms_helper,i915
video                  49152  1 i915
But after the driver installation I lost the i915 driver:
Graphics:
  driver: N/A
  Display: server: X.org 1.20.9 driver: fbdev unloaded: modesetting,vesa
  tty: 80x24
  Message: No advanced graphics data found on this system.
[sudo] password for helio:
  *-display UNCLAIMED
       physical id: 2
       version: 06
       width: 64 bits
       clock: 33MHz
       configuration: latency=0
       resources: memory:f7800000-f7bfffff memory:e0000000-efffffff ioport:f000(size=64) memory:c0000-dffff
(nothing)
Without this i915 driver, Ubuntu uses a generic one that has no full HD support.
I tried to reinstall the missing i915 but never had any success.
Can anyone give me a tip on what to do?
Regards
hsmptg
Re: tbs-open-linux-driver swipes Ubuntu 20.04 graphics drive
Postby hsmptg » Sun Apr 11, 2021 10:56 pm
Just to inform that tbs-open-linux-drivers_v20210204 with Ubuntu 18.04 do not cause the problem I reported in my initial post.
So I will use Ubuntu 18.04 until someone find a solution.
Regards
hsmptg
Postby s0nnenschein » Mon Apr 12, 2021 3:40 am
Yes, I can confirm that bug. :(
First I thought I was wrong, but then I tried it under the previous kernel (which I selected in GRUB2).
Have Ubuntu 20.04, media_build-2021-02-04.tar.bz2 and Kernel 5.8.0-45-generic and 5.8.0-48-generic
I cannot set the LCD brightness any more.
Update:
sudo rm -rf /lib/modules/`uname -r`/kernel/drivers/media/
does NOT help here.
I fear some energy savings have been disabled, the CPU is now much hotter ...
s0nnenschein
Postby s0nnenschein » Thu Apr 15, 2021 1:03 pm
Yesterday kernel 5.8.0-49-generic was installed, the graphics card driver does now work again.
In case I want to use a TBS product, I need to boot with the previous kernel (select 5.8.0-48-generic in GRUB2).
s0nnenschein
Postby dabbler123 » Wed May 05, 2021 7:46 pm
The break has occurred between Ubuntu kernels 5.8.0-44-generic and 5.8.0-45-generic.
If I re-install kernel 5.8.0-44-generic and compile tbs-open-linux-drivers_v20210204 then both the TBS drivers and video drivers (ast) load correctly.
As soon as I install any kernel > 5.8.0-44-generic then the tbs drivers load but video drivers fails with following errors:
[45326.666262] drm_kms_helper: disagrees about version of symbol cec_delete_adapter
[45326.666264] drm_kms_helper: Unknown symbol cec_delete_adapter (err -22)
[45326.666585] drm_kms_helper: disagrees about version of symbol cec_transmit_attempt_done_ts
[45326.666586] drm_kms_helper: Unknown symbol cec_transmit_attempt_done_ts (err -22)
[45326.667233] drm_kms_helper: disagrees about version of symbol cec_s_phys_addr
[45326.667234] drm_kms_helper: Unknown symbol cec_s_phys_addr (err -22)
[45326.667273] drm_kms_helper: disagrees about version of symbol cec_s_conn_info
[45326.667274] drm_kms_helper: Unknown symbol cec_s_conn_info (err -22)
[45326.667344] drm_kms_helper: disagrees about version of symbol cec_s_phys_addr_from_edid
[45326.667345] drm_kms_helper: Unknown symbol cec_s_phys_addr_from_edid (err -22)
[45326.668903] drm_kms_helper: disagrees about version of symbol cec_unregister_adapter
[45326.668904] drm_kms_helper: Unknown symbol cec_unregister_adapter (err -22)
[45326.669380] drm_kms_helper: disagrees about version of symbol cec_allocate_adapter
[45326.669381] drm_kms_helper: Unknown symbol cec_allocate_adapter (err -22)
[45326.669975] drm_kms_helper: disagrees about version of symbol cec_fill_conn_info_from_drm
[45326.669976] drm_kms_helper: Unknown symbol cec_fill_conn_info_from_drm (err -22)
[45326.670100] drm_kms_helper: disagrees about version of symbol cec_received_msg_ts
[45326.670101] drm_kms_helper: Unknown symbol cec_received_msg_ts (err -22)
[45326.670428] drm_kms_helper: disagrees about version of symbol cec_register_adapter
[45326.670429] drm_kms_helper: Unknown symbol cec_register_adapter (err -22)
There is a breaking change at kernel 5.8.0-45-generic that needs an update - please investigate.
dabbler123
Postby dabbler123 » Sat May 08, 2021 5:15 pm
Support have stated it is best to lock at a known good working kernel (not ideal but it works):
"If both tbs driver and graphics drivers both works fine in kernel 5.8.0-44, please downgrade to 5.8.0-44 and use it.
Maybe it relates to kernel, maybe it's the conflict of 2 drivers. Currently, does not have a good solution for this.
When you downgrade to 5.8.0-44, please run the following cmd to hold this kernel:
# apt-mark hold linux-image-generic linux-headers-generic
for kernel, no need to upgrade frequently, and normally, the defaul is the best."
dabbler123
Postby satesco » Wed Jun 02, 2021 4:09 pm
Hi Steven,
I have the same problem that those who posted above,namely,once the dvb drivers are installed on ubuntu 20.04,and working fine,the resolution changed from 1920x1080 to 1280x768. I managed with difficulty,after an upgrade to the graphics card,to return to the initial resolution,but now Ubuntu sees cards but without drivers.Now I'm afraid to reinstall them,so that the same problem with the resolution does not return,as the first time.
I have to say that two times I reinstalled Ubuntu 20.04 version,believing that I made a mistake somewhere in the process of installing the tbs drivers.Unfortunately I did not manage to solve the problem. For now I have the correct monitor resolution but without the tbs drivers installed.What do you think I should do,to wait until a forum colleague comes up with a solution to the reported problem or go back to unbuntu 18.04,when everything was working fine?
Here is Ubuntu 20.04 (kerner5.8.0-50) with tbs cards.
Regards
satesco
Postby zhangchao » Fri Jun 04, 2021 4:09 pm
hi ,
1. update kernel to a new version .
2. please add skype jack_2431 or write email to support@tbsdvt.com .
best regards!
zhangchao
Postby satesco » Mon Jun 07, 2021 8:53 pm
Because I could not install the drivers for ubuntu 20.04 without the risk of a wrong resolution for my monitor, after many attempts, even with version 5.8.0-55,with the same disastrous results,I went back to version 18.04. Installing the drivers for cards tbs went well and works.
Actually which of the kerner versions is valid for tbs cards on ubuntu 20.04?
Thanks.
satesco
Postby crazycat » Mon Jun 07, 2021 9:27 pm
For 20.04.2+ possible switch to 5.4 GA kernel
https://wiki.ubuntu.com/Kernel/LTSEnabl ... ocal_Fossa
