22KHz "Locked on" - unable to get 10GHz - only 11700-12000+
Postby bigbloke » Mon Apr 05, 2021 8:32 pm
HI All,
Due to a necessary reconfiguration of PCs to run some ancient (non satellite) software no longer supported
by windows 10 , and some incredibly cheap Small Form Factor I7 based PCs for sale that allowed me to
do it, My satellite configuration is as follows:
I5 Motherboard 4GB RAM
Windows 7 Pro 32 bit (I have to run 32 bit for the old software - It needs NTVDM.EXE)
6982 PICe card with latest windows 7 driver x.x.x.6
HH120 positioner
Universal PLL LNB
software in use is progdvb pro X86 7.40
I am not using the windows 10 machines for sattlelite as they are too small (SFF) to take my 6982 card.
and I am not wasting an i7 on 32 bit windows 7!
The software and hardware appeared to run very well and I have many channels , but when testing with 26E (BADR / E'sHail1/2)
I noticed that no signal below 11.7 GHz was being found , implying that either the TBS card is always transmitting 22KHz ,
or the LNB was faulty. I checked other satellites - these were the same.
I disconnected the TBS card and put in its place my GTMedia V8 Gold meter...
Instant success! I could watch and tune 10 & 12 GHZ signals, proving there was no issue with the LNB
reconnect the TBS card, only 11700-12000+ signals are visible ? very odd.
SO it could be:
A TBS hardware fault
A TBS driver fault
A ProgDVB fault
I tried to run the trial of dvb dream - it just crashes constantly on this PC
Anyone come across this before please ? any idea how to fix it ?
Regards
BB
bigbloke
Re: 22KHz "Locked on" - unable to get 10GHz - only 11700-120
Postby smile » Fri Apr 09, 2021 10:07 am
HI
Please check you LNB info. if it is the Ku-Linear (low band: 9750 MHz switch :11700MHz high:10600),when the 22k turn on that mean it is the High band, the frequencies is higher than 11700(the switch values). conversely , 22k turn off, the frequencies lower than 11700.
Best Regards
smile
