TBS6902 - no input source available
Postby KenyBDG » Wed Mar 17, 2021 10:23 pm
From few years I'm using TBS6902 with TVH 4.2.8-34 and everything work well.
Because I can watch only two channels simultaneously I decided to buy same TBS6902.
After installation the card has been detected by TVH without any issue, but when unfortunately I cannot watch anything using this new card.
I've noticed on TVH log,
2021-03-09 20:02:32.973 subscription: 00C0: No input source available for subscription"
Maybe card is broken, but before I send back to seller, I'd like to be sure that everything is ok on my side.
I've been testing also just one card to be sure that power supply is ok, but there is no matter, if I use one or both card.
Of course old one TBS6902 work fine.
KenyBDG
Re: TBS6902 - no input source available
Postby smile » Mon Mar 22, 2021 10:47 am
Sorry , The problem is caused by the new 6902 H/V voltage control . the new 6902 send the wrong command for control the H/V. now the problem is fixed.
please update to the latest:
update instructions: https://github.com/tbsdtv/linux_media/c ... 4aae6dd030
update step: https://github.com/tbsdtv/linux_media/wiki
Thanks for your feedback.
Best Regards
Davin
smile
