[ Moderator Control Panel ]
TBS2603SE is a professional HDMI video encoder, which supports 1 channel HDMI stream of H.264/H.265 encoding output and the AAC, Mp3 audio format, and it can work with NDI®|HX compatible systems.
by SteveP » Tue Mar 16, 2021 2:53 pm
Before I make a purchase, can anybody tell me if the m3u8 stream from the TBS2603se is playable with something like this...
https://jsfiddle.net/2m9dawy7/It's a very simple JSFiddle that uses videojs and videojs-contrib-hls to play a m3u8 stream in a browser (if you would like to test it, simply change the url on line 2 to your m3u8 url).
My requirement would be to play the encoded HDMI stream in a range of browsers, and surprisingly, this seems to be much trickier than it should be.
Cheers,
Steve.
SteveP
by steven » Sun Mar 21, 2021 8:14 am
Hi Sir
we already tested our HLS output stream in some browse which works well , such as chrome ,EDGE ...
Return to TBS2603se Professional HD H.265/H.264 HDMI Video Encoder
