TBS5520SE IP tool is not working
Postby GlowingRadio » Wed Feb 10, 2021 5:34 am
I have tried to use the IP tool 3.0.5.5 on Windows 10 without success so far. The IP over DVB status says "Device opened successfully", but then I am not able to lock any transponder.
The error log says:
[02/09/21 22:13:58 : 409937] BDA Device Name: [TBS 5520 BDA Tuner] (Tuner Type:1)
[02/09/21 22:13:58 : 409984] FAILED: cannot connect network provider to tuner filter
[02/09/21 22:13:58 : 409984] << OnInitDialog OK!!
[02/09/21 22:14:24 : 436171] << OnOK m_pKsCtrl Failed !
I am using version 1.0.0.8 of the driver. Could you please help?
GlowingRadio
Re: TBS5520SE IP tool is not working
Postby steven » Sat Feb 13, 2021 9:12 am
hi sir
which mode you are using with your 5520se ?
Postby GlowingRadio » Mon Feb 15, 2021 12:47 am
Hello Steven
It's DVB-C.
GlowingRadio
Postby steven » Sun Feb 21, 2021 11:16 am
hi sir
TBSIPTool only for DVB-S , for DVB-C there is no need to use it .
