TBS 6004
TBS 6004
Postby spiplus » Fri Feb 05, 2021 3:25 pm
Hello
I hav problem to install modulator card TBS 6004 on Linux.
I was try install and installation is ok but driver no. I dont see card on web panel.
03:00.0 Multimedia controller: TBS Technologies DVB-S2 4 Tuner PCIe Card
it was wrong driver.
Any ho know what is the driver for 6004
on centos 7
make[4]: *** [/root/media_build/v4l/msp3400-kthreads.o] Error 1
make[3]: *** [/root/media_build/v4l] Error 2
make[2]: *** [sub-make] Error 2
make[2]: Leaving directory `/usr/src/kernels/5.4.95-1.el7.elrepo.x86_64'
make[1]: Leaving directory `/root/media_build/v4l'
make: *** [all] Error 2
spiplus
Re: TBS 6004
Postby spiplus » Fri Feb 05, 2021 8:22 pm
0b:00.0 Multimedia controller [0480]: TBS Technologies DVB-S2 4 Tuner PCIe Card [544d:6178]
Subsystem: Device [6004:0001]
Physical Slot: 1
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR- FastB2B- DisINTx-
Interrupt: pin A routed to IRQ 5
Region 0: Memory at fdfc0000 (32-bit, non-prefetchable) [size=256K]
Capabilities: [70] MSI: Enable- Count=1/1 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [90] Express (v1) Endpoint, MSI 00
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
DevCtl: Report errors: Correctable- Non-Fatal+ Fatal+ Unsupported-
MaxPayload 128 bytes, MaxReadReq 4096 bytes
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s, Exit Latency L0s unlimited, L1 <1us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
Capabilities: [100 v1] Device Serial Number 00-00-00-00-00-00-00-00
Linux SPI-***** 4.4.0-201-generic #233-Ubuntu SMP Thu Jan 14 06:10:28 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
spiplus
Re: TBS 6004
Postby steven » Mon Feb 08, 2021 4:40 pm
Hi Sir
Please send email to our support@tbsdtv.com, and you can add my colleague skype :jack_2431
he will help you with this
kind Regards
