TBS 5520SE not recognized for S/S2 service
Postby rolfd » Thu Jan 21, 2021 12:18 am
i just installed and compiled the software an my mediaserver. The USB tuner card TBS 5520SE is only recognized as DVB-T/T2 oder DVB-C/C2 and ISDB-T service. Sat service is not shown and so I am unable to configure the LNB.
Do anybody have an idea what is going wrong?
The usb-box is correct initialized
Jan 20 17:03:07 MediaServer kernel: [ 70.349944] dvb-usb: found a 'TurboSight TBS 5520SE' in cold state, will try to load a firmware
Jan 20 17:03:07 MediaServer kernel: [ 70.538483] dvb-usb: downloading firmware from file 'dvb-usb-id5520se.fw'
Jan 20 17:03:07 MediaServer kernel: [ 70.663131] dvb-usb: found a 'TurboSight TBS 5520SE' in warm state.
Jan 20 17:03:07 MediaServer kernel: [ 70.663309] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
Jan 20 17:03:07 MediaServer kernel: [ 70.663324] dvbdev: DVB: registering new adapter (TurboSight TBS 5520SE)
Jan 20 17:03:07 MediaServer kernel: [ 70.663329] dvb-usb: MAC address reading failed.
Jan 20 17:03:07 MediaServer kernel: [ 71.635228] dvb-usb: no frontend was attached by 'TurboSight TBS 5520SE'
Jan 20 17:03:07 MediaServer kernel: [ 71.635232] dvb-usb: TurboSight TBS 5520SE successfully initialized and connected.
Jan 20 17:03:07 MediaServer kernel: [ 71.635582] dvb-usb: TurboSight TBS 5520SE successfully deinitialized and disconnected.
Jan 20 17:03:07 MediaServer kernel: [ 72.456605] dvb-usb: found a 'TurboSight TBS 5520SE' in cold state, will try to load a firmware
Jan 20 17:03:07 MediaServer kernel: [ 72.456608] dvb-usb: downloading firmware from file 'dvb-usb-id5520se.fw'
Jan 20 17:03:07 MediaServer kernel: [ 72.579134] dvb-usb: found a 'TurboSight TBS 5520SE' in warm state.
Jan 20 17:03:07 MediaServer kernel: [ 72.579354] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
Jan 20 17:03:07 MediaServer kernel: [ 72.579482] dvbdev: DVB: registering new adapter (TurboSight TBS 5520SE)
Jan 20 17:03:07 MediaServer kernel: [ 72.677333] dvb-usb: MAC address: 00:22:ab:c0:59:df
Jan 20 17:03:07 MediaServer kernel: [ 72.836549] dvb-usb: TurboSight TBS 5520SE successfully initialized and connected.
Ithe box is recognized as TBS 5520SE. In mythtv is see only the dvb-c/t/ and other services no sat servive S/S2.
regards
Rolf
rolfd
Re: TBS 5520SE not recognized for S/S2 service
Postby smile » Fri Jan 22, 2021 4:22 pm
Hi sir
please check the adapter file .
$# ls /dev/dvb/adapter0
is there a "frontend1" in that file.
or you can try use the TVH. maybe mythtv can not support this cards framework.
Best Regards
smile
