How to stop streaming of encoder
TBS2603SE is a professional HDMI video encoder, which supports 1 channel HDMI stream of H.264/H.265 encoding output and the AAC, Mp3 audio format, and it can work with NDI®|HX compatible systems.
Postby SergioRodOrt » Tue Jan 19, 2021 11:24 pm
Hi all,
I have just started to use a TBS2603se encoder and I don´t know if it is possible to stop the streaming without switching the encoder off with the electric cable.
Other think I want to know is if it is possible to configure the encoder in command line.
Thanks in advance!
SergioRodOrt
Re: How to stop streaming of encoder
Postby daowei » Fri Jan 22, 2021 3:17 pm
Yes, sure. you can stop the streaming without turning Encoder off. Just go to web UI and Page "Stream", to disable the protocol.
For example, http is streaming, then just go to "disable" http.
Return to TBS2603se Professional HD H.265/H.264 HDMI Video Encoder
