TBS5520SE DiSEqC problems
Postby babau » Sat Jan 02, 2021 9:00 pm
Hallo, I am new in the forum, thank you for accepting!
I have a problem with my TBS5520SE: the switching of DiSEqC doesn't work.
The DiSEqC relay is a Spaun SAR 212 WSG (DiSEqC 2.0 with 2 inputs), and works perfectly with a normal Sat-receiver.
I've tried all the possible configurations in Crazyscan (A/A, A/B, B/A, B/B, Tone A, Tone B) but the switch always remains set to LNB input 1.
Thank you for your help
babau
Re: TBS5520SE DiSEqC problems
Postby steven » Mon Jan 04, 2021 9:21 am
Hi Sir
Can you have a try with another application such as our OEM-DVBDream:
https://www.tbsiptv.com/download/common/dvbdream_oem_version_setup_v296.zip
Postby babau » Tue Jan 05, 2021 5:05 am
Thank you! With DVBDream it works...
So the problem was Crazyscan: after several attempts I realized that I had to check the parameter "Multiswitch". Then the DiSEqC works properly setting A/A(1) or B/A(2) in the "DiSEqC" box.
babau
Postby steven » Tue Jan 05, 2021 2:05 pm
Hi Sir
Thanks for your update so it is the setting issue , if you have any more problem please feel free to ask us
