Driver Linux. Debian 9&10
Postby krlozs » Tue Dec 15, 2020 6:56 am
Hi, I am trying the solutions you gave in the forum to be able to install the 6522 driver; but even with manuel, I have not been successful. What am I failing at? ... I have tested it under Debian 10 and Debian 9. Thanks.
krlozs
Re: Driver Linux. Debian 9&10
Postby steven » Tue Dec 15, 2020 11:45 am
Hi Sir
Which kernel version you are using ? please have a try with this package :
# wget http://www.tbsdtv.com/download/document/linux/media_build-2020-12-04.tar.bz2
#tar jxvf media_build-2020-12-04.tar.bz2
#cd media_build
#./install.sh
#reboot
Postby krlozs » Tue Dec 15, 2020 4:39 pm
root@iptv:/home/krlozs# uname -a
Linux iptv 4.9.0-14-amd64 #1 SMP Debian 4.9.240-2 (2020-10-30) x86_64 GNU/Linux
krlozs
Postby krlozs » Tue Dec 15, 2020 4:44 pm
After installing and restarting what you sent me, it appears that it cannot find the driver.
root@iptv:/home/krlozs# dmesg | grep frontend
root@iptv:/home/krlozs# lspci -vvv | grep 6522
        Subsystem: Device 6522:0002
pcilib: sysfs_read_vpd: read failed: Input/output error
krlozs
Postby sanenr » Thu Dec 17, 2020 1:52 am
krlozs Wrote:After installing and restarting what you sent me, it appears that it cannot find the driver.
The same problem over here! , same mesage!
tbs tuner card 6522, linux debian scratch 4.9.0-14-amd64 tbs-driver: media_build-2020-12-04.tar.bz2
i tried the same steps ,header installed without success!
thanks in advance for your support! from Ecuador kindly regards!
sanenr
Postby steven » Thu Dec 17, 2020 6:16 pm
this information is not the tuner card
Please send email to our support and setup SSH remote let us remote install for you
Postby krlozs » Fri Dec 18, 2020 8:25 am
Hi, the tuner card is being recognized by the debian with the command "pcilist" and what is the support email? ... thanks.
krlozs
Postby steven » Fri Dec 18, 2020 9:42 am
hi sir
you can send email to support@tbsdtv.com
