LNB B exhibits signal problem until system reboot
Postby fgt67 » Sun Nov 15, 2020 5:22 am
My TBS 6981 card has a weird issue with LNB B where there are continuous continuity errors until the system is rebooted. On a cold boot LNB B will not work and it will appear that the signal is extremely weak or badly grounded. Once the system is rebooted the tuner works and there are no problems. LNB A is unaffected and works every time although I have noticed that tuning to LNB B will sometimes interferes with it causing a momentary signal blip.
Is the card faulty or is this some driver/firmware issue? It will only work after a reboot straight after being powered on. I have tried the card in 3 different computers and all have the same problem and it's also not a problem with the dish/LNB or cable as that has worked fine with other tuners for years.
fgt67
Re: LNB B exhibits signal problem until system reboot
Postby steven » Mon Nov 16, 2020 10:48 am
Hi Sir
From the information you provide looks the 6981 have hardware issue you can think about update the card to TBS6902:
https://shop.tbsdtv.com/tbs6902-dvbs2-d ... p-135.html
