Asus Rog Strix X570i Compatibility
Postby bermondse1 » Sat Oct 17, 2020 7:50 pm
Hi everyone,
I've recently upgraded my HTPC to an Asus ROG Strix X570 motherboard and Ryzen 3400G.
I'd hoped I'd be able to reuse my old but trusty 6280 on the new board as I was migrating from an old Asus Maximus Gene-Z/Gen 3 board.
Unfortunately, the new board doesn't recognise the 6280 as a tv tuner, seems to think it's a graphic card and hence I get no video output at all to the TV when I boot with the card in the PCIE slot.
I've tried setting the PCIe link to Gen 1 in the Bios and also forcing the bios to use the 3400G's integrated graphics but still no luck.
Hence on the look out for a replacement card - so want to check if the 6281SE is compatible with the latest ASUS/AMD boards?
Cheers!
bermondse1
Re: Asus Rog Strix X570i Compatibility
Postby steven » Thu Oct 22, 2020 10:04 am
Hi Sir
6281Se is using new PCIE bridge which have not this issue ,do not need to worry
Return to PCIe DVB-T2/T/C Dual Tuner Card TBS6281SE
