Kernel 5.8.13-arch1-1 and TBS6981
Postby trumee » Mon Oct 05, 2020 12:49 am
My system has 5.8.13 kernel and it detects the TBS 6981 card,
$ dmesg | grep cx238
[   25.604771] cx23885: cx23885 driver version 0.0.4 loaded
[   25.604807] cx23885 0000:03:00.0: enabling device (0000 -> 0002)
[   25.604918] cx23885: CORE cx23885[0]: subsystem: 6981:8888, board: TurboSight TBS 6981 [card=40,autodetected]
[   27.828181] cx25840 8-0044: cx23885 A/V decoder found @ 0x88 (cx23885[0])
[   28.453582] cx25840 8-0044: loaded v4l-cx23885-avcore-01.fw firmware (16382 bytes)
[   28.466931] cx23885: cx23885_dvb_register() allocating 1 frontend(s)
[   28.466932] cx23885: cx23885[0]: cx23885 based dvb card
[   28.471211] dvbdev: DVB: registering new adapter (cx23885[0])
[   28.471213] cx23885 0000:03:00.0: DVB: registering adapter 0 frontend 0 (Conexant CX24117/CX24132)...
[   28.471470] cx23885: cx23885_dvb_register() allocating 1 frontend(s)
[   28.471470] cx23885: cx23885[0]: cx23885 based dvb card
[   28.471474] dvbdev: DVB: registering new adapter (cx23885[0])
[   28.471475] cx23885 0000:03:00.0: DVB: registering adapter 1 frontend 0 (Conexant CX24117/CX24132)...
[   28.471619] cx23885: cx23885_dev_checkrevision() Hardware revision = 0xa5
[   28.471622] cx23885: cx23885[0]/0: found at 0000:03:00.0, rev: 4, irq: 16, latency: 0, mmio: 0xdc200000
Unfortunately, if i try to do a blind scan with w_scan2 i get messages that "freq 6.21 unsupported by driver: min=0.95, max=2.15". Is this frequency a limitation of the opensource driver?
trumee
Re: Kernel 5.8.13-arch1-1 and TBS6981
Postby trumee » Mon Oct 05, 2020 12:50 am
Here is the full log,
# w_scan2 -c IN -fs -s S83E0 -G
w_scan2 version 1.0.9 (compiled for DVB API 5.11)
using settings for 83.0 east Insat 2E/4A
scan type SATELLITE, channellist 37
output format gstreamer
WARNING: could not guess your codepage. Falling back to 'UTF-8'
output charset 'UTF-8', use -C <charset> to override
Info: using DVB adapter auto detection.
/dev/dvb/adapter0/frontend0 -> SATELLITE "Conexant CX24117/CX24132": very good :-))
Using SATELLITE frontend (adapter /dev/dvb/adapter0/frontend0)
Using DVB API 5.11
frontend 'Conexant CX24117/CX24132' supports
INVERSION_AUTO
DVB-S
DVB-S2
FREQ (0.95GHz ... 2.15GHz)
SRATE (1.000MSym/s ... 45.000MSym/s)
using LNB "UNIVERSAL"
trying 'S f = 3521 kHz V SR = 8640 3/4 0,35 QPSK (0:0:0)'
(time: 00:00.093) skipped: (freq 6.23 unsupported by driver: min=0.95, max=2.15)
initial_tune:3327: Setting frontend failed S f = 3521 kHz V SR = 8640 3/4 0,35 QPSK (0:0:0)
trying 'S f = 3537 kHz V SR = 10800 3/4 0,35 QPSK (0:0:0)'
(time: 00:01.233) skipped: (freq 6.21 unsupported by driver: min=0.95, max=2.15)
initial_tune:3327: Setting frontend failed S f = 3537 kHz V SR = 10800 3/4 0,35 QPSK (0:0:0)
trying 'S f = 3725 kHz H SR = 26665 3/4 0,35 QPSK (0:0:0)'
(time: 00:02.369) skipped: (freq 6.03 unsupported by driver: min=0.95, max=2.15)
--clip----
initial_tune:3327: Setting frontend failed S f = 4180 kHz H SR = 3233 3/4 0,35 QPSK (0:0:0)
trying 'S2 f = 10970 kHz H SR = 28500 3/4 0,AUTO 8PSK (0:0:0)'
(time: 00:42.242)
trying 'S f = 11010 kHz H SR = 27500 3/4 0,35 QPSK (0:0:0)'
(time: 00:50.515)
trying 'S f = 11050 kHz H SR = 30000 7/8 0,35 QPSK (0:0:0)'
(time: 00:56.102)
trying 'S f = 11090 kHz H SR = 30000 7/8 0,35 QPSK (0:0:0)'
(time: 01:01.715)
trying 'S f = 11130 kHz H SR = 30000 7/8 0,35 QPSK (0:0:0)'
(time: 01:07.328)
trying 'S f = 11170 kHz H SR = 30000 7/8 0,35 QPSK (0:0:0)'
(time: 01:12.925)
trying 'S f = 11470 kHz H SR = 30000 7/8 0,35 QPSK (0:0:0)'
(time: 01:18.512)
trying 'S f = 11510 kHz H SR = 30000 7/8 0,35 QPSK (0:0:0)'
(time: 01:24.115)
trying 'S f = 11550 kHz H SR = 30000 7/8 0,35 QPSK (0:0:0)'
(time: 01:29.711)
trying 'S f = 11590 kHz H SR = 30000 7/8 0,35 QPSK (0:0:0)'
(time: 01:35.298)
trying 'S f = 11630 kHz H SR = 30000 7/8 0,35 QPSK (0:0:0)'
(time: 01:40.901)
trying 'S f = 11670 kHz H SR = 30000 7/8 0,35 QPSK (0:0:0)'
(time: 01:46.495)
ERROR: Sorry - i couldn't get any working frequency/transponder
Nothing to scan!!
trumee
Postby steven » Fri Oct 09, 2020 2:35 pm
please have a try with another application such as dvblast check whether you can get lock
Postby trumee » Sat Oct 10, 2020 2:14 am
I was able to get this going after updating the frequency table.
trumee
