Can't use TBS 5980 driver for Linux
Postby purplecolour » Fri Aug 28, 2020 8:29 pm
Hi, so I'm using Debian 10 and I can't get the driver to work, the kernel version that is used is 4.19.0-10 and I have follow these steps
#wget https://www.tbsdtv.com/download/documen ... 23.tar.bz2
#tar jxvf media_build-2020-05-23.tar.bz2
#cd media_build
#./install.sh
#reboot
Hope you guys can help me, thank you!
purplecolour
Re: Can't use TBS 5980 driver for Linux
Postby steven » Tue Sep 01, 2020 10:19 am
Do you have any error log ? and you can have a try with this package :
# wget http://www.tbsdtv.com/download/document/linux/media_build-2020-07-07.tar.bz2
#tar jxvf media_build-2020-07-07.tar.bz2
#cd media_build
#./install.sh
#reboot
