TBS 6909-X driver
TBS 6909-X driver
Postby Tiborg » Fri Aug 14, 2020 9:16 am
I'm using win10 64bit. I connected the TBS6909-x card correctly to the pcie slot on my motherboard,
I tried to install the driver countless times but it doesn't recognize! I tried to install the driver directly and was not successful!
I put all the images of the step by step I used https://gyazo.com/5dac6aaa418036b9e3734a53d11e2c30
and still no use, because what good is the card without a driver? https://gyazo.com/1fc0c20cbdf634af0aea2bf3b7f7a796
So I ask for your help
Tiborg
Re: TBS 6909-X driver
Postby daowei » Fri Aug 14, 2020 11:17 am
Can you show us the "hardware ID"? right click "Control De xxx"---and then " properties"---details: there, you can see the hardware ID.
Please take a photo to us.
Postby Tiborg » Mon Aug 17, 2020 11:00 pm
hi, TBS support came in via Teamviewer and installed another version of the driver, now my problem is different. on the satellite TV receiver (Freesky triple x) there is a good signal and I see all the channels without locking up. When I connect the same lnb cable to the TBS6909-x board, there is no signal and no channels are found! https://gyazo.com/d1ae177e4e1f076d7c61121999e4be9a I use that same frequency on my normal receiver and I see all the channels, but nothing on the TBS board
Tiborg
