TBS6522 Windows 10 v2004 - Bluescreen
Postby Andi1984 » Sun Jun 21, 2020 9:05 pm
After my last bluescreen problem with using TBS6522 tuner card under Windows 10 x64 v1909 has been solved by new drivers (tbs6522_release_V1015_beta, see here: viewtopic.php?f=195&t=25365#p55453), I recently updated to the newly released "20H1" version of Windows 10 (v2004).
And with this new Windows 10 version, I get a similar problem again:
But I always get a Bluescreen in tbs6522.sys during the update. There's no way to install the update, after resetting the PC from the bluescreen, it reverts back to the previous Windows version (v1909).
Best regards,
Andi
Andi1984
Re: TBS6522 Windows 10 v2004 - Bluescreen
Postby steven » Mon Jun 22, 2020 11:15 am
Hi Sir
Before update the windows 10 please try to remove the 6522 card first uninstall the driver ,then update the system .
when finished update then start install the 6522 and the driver
Postby Andi1984 » Wed Jun 24, 2020 6:17 pm
I will try this today and provide feedback then.
Best regards,
Andi
Andi1984
Postby Andi1984 » Wed Jun 24, 2020 8:34 pm
steven Wrote:Before update the windows 10 please try to remove the 6522 card first uninstall the driver ,then update the system .
Many thanks for the hint.
It worked well this way.
Best regards,
Andi
Andi1984
Re: TBS6522 Windows 10 v2004 - Bluescreen(sloved)
Postby steven » Sun Jun 28, 2020 11:46 am
Thanks for your update
Postby Andi1984 » Mon Aug 17, 2020 5:29 pm
I again have the bluescreen issue after the latest update to Windows 10 20H1 Version: 19041.450.
And this time, the old trick:
does not work.
This means:
- I uninstall the TBS6522 driver and reboot
- I install the Windows update to version 19041.450 and reboot
- I install the TBS6522 driver again (OK)
- I reboot the system -> Blue screen
Best regards,
Andi
Andi1984
Postby steven » Tue Aug 18, 2020 10:37 am
Hi Sir
For the windows 10 20 version we find some issue too , if possible please reintall with the older version first
let us have more check
Postby Andi1984 » Sun Oct 18, 2020 4:07 pm
Is there any update?
Best regards,
Andi
Andi1984
Postby steven » Mon Oct 19, 2020 4:10 pm
Hi Sir
Sorry that no update yet ,please continue use the v19 version first
Postby Andi1984 » Sun Dec 20, 2020 5:02 pm
Any update?
Best regards,
Andi
Andi1984
