Rebuilding software for TBS 6281 card
Postby mollcons » Tue Jun 09, 2020 2:35 am
I have been successfully using the script at https://github.com/tbsdtv/linux_media/wiki now for a couple of years on my Fedora PC. This has been successful with all Fedora versions by and large until yesterday. I am now on Fedora 32 and using kernel 5.6.15-300.fc32.x86-64.
Now I get an error at the end of the command 'make -j4' which shows:
ERROR: "fwnode_get_name" [/export/home/root/media_build/v4l/v4l2-fwnode.ko] undefined!
ERROR: "__devm_regmap_init_sccb" [/export/home/root/media_build/v4l/ov9650.ko] undefined!
make[3]: *** [scripts/Makefile.modpost:93: __modpost] Error 1
make[2]: *** [Makefile:1608: modules] Error 2
make[2]: Leaving directory '/usr/src/kernels/5.6.15-300.fc32.x86_64'
make[1]: *** [Makefile:53: default] Error 2
make[1]: Leaving directory '/export/home/root/media_build/v4l'
What do I need to do to overcome this issue?
mollcons
Re: Rebuilding software for TBS 6281 card
Postby steven » Tue Jun 09, 2020 2:39 pm
# wget http://www.tbsdtv.com/download/document/linux/media_build-2020-05-22.tar.bz2
#tar jxvf media_build-2020-05-22.tar.bz2
#cd media_build
#./install.sh
#reboot
Postby mollcons » Wed Jun 10, 2020 6:33 am
Steven
That does not appear to have worked. I have a test script which performs the following checks:
dmesg | grep -i saa716
grep saa716x /etc/modprobe.d/*
lspci -v | grep --after-context=10 7160
ls -al /dev/dvb
lsdvb
lsmod
I am attaching the log for this script.
mollcons
Postby steven » Wed Jun 10, 2020 2:30 pm
# wget http://www.tbsdtv.com/download/document ... 23.tar.bz2
#tar jxvf media_build-2020-05-23.tar.bz2
#cd media_build
#./install.sh
#reboot
please have a try with this new version , if still failed please send the SSH remote to our support@tbsdtv.com
we will remote install for you
thanks
Postby mollcons » Wed Jun 10, 2020 8:24 pm
Again it did not work.
I have been successfully using the scripts at https://github.com/tbsdtv/linux_media/wiki until this latest update, What has changed other than the Fedora version?
What do you mean by SSH remote? I have a Draytek 2830 router that controls external access to my network, which includes several Windows PC's as well as this Fedora server.
mollcons
Postby tvbob » Wed Jun 17, 2020 5:42 pm
Any update on this? I am also seeing the same error attempting to compile for a 6982 under Arch linux.
ERROR: "fwnode_get_name" [/root/tbs-driver/media_build/v4l/v4l2-fwnode.ko] undefined!
make[2]: Leaving directory '/usr/lib/modules/5.6.15-arch1-1/build'
make[1]: Leaving directory '/root/tbs-driver/media_build/v4l'
tvbob
Postby zhangchao » Thu Jun 18, 2020 3:19 pm
enter a new directoy .
#cd /opt/
#cd media_build
#./install.sh
#reboot
if also has issue , please setup remote control. many curstormer can install successfully using this command .
zhangchao
Postby tvbob » Thu Jun 18, 2020 6:16 pm
Thanks zhangchao,
The link in your message has been trimmed. Are you able to post the full download link?
tvbob
Postby steven » Thu Jul 02, 2020 11:17 am
hi
please check this
# wget http://www.tbsdtv.com/download/document/linux/media_build-2020-05-23.tar.bz2
#cd media_build
#./install.sh
#reboot
Postby Scritch » Sun Jul 05, 2020 5:29 pm
This fixed the compile error for me on Armbian (same 5.6 kernel)
echo "#define NEED_FWNODE_GETNAME 1" > ./media_build/v4l/config-mycompat.h
Scritch
