tbs 6590 error
tbs 6590 error
Postby joker » Wed Jun 03, 2020 2:08 pm
hi y have this error and no service
Info: DVB: =========== Card 0 - Tuner 1 ===========
Info: DVB: Frontend : TurboSight TBS 6590 DVB-S/S2/S2X/T/T2/C/C2/ISDB-T +
Info: DVB: Satellite (DVB-S) card
Info: DVB: Frequency: 950000 kHz to 2150000 kHz
Info: DVB: Symbol rate: 1000 k symbols/s to 45000 k symbols/s
Info: DVB:
ERRO: DVB: FRONTEND DEVICE: /dev/dvb/adapter0/frontend0 : Device or resource busy
ERRO: DVB: FE_GET_INFO: Bad file descriptor
ERRO: DVB: FRONTEND DEVICE: /dev/dvb/adapter1/frontend1 : Device or resource busy
ERRO: DVB: FRONTEND DEVICE: /dev/dvb/adapter1/frontend0 : Device or resource busy
joker
Re: tbs 6590 error
Postby steven » Wed Jun 03, 2020 5:23 pm
hi
it means the tuner is used by other application please make sure that one tuner only can be used by one application at the same time
