TBS6304 with Tvheadend
TBS6304 HD HDMI Capture Card comes with HDMI1.4 port, completely support full HD Video and Audio capture and playback. It provides 4 HDMI inputs of highest quality, and meets the HDMI 1.4 standard, satisfies the 1080P resolutions and can capture the LPCM audio signals in HDMI. Moreover, it supports H.264 hardward compression and HDCP. You can easily capture signals from different kinds of devices by TBS6304 HDMI Capture Card without limitation.
Postby gsm42 » Mon May 11, 2020 10:46 pm
I wonder if it's possible tu use this capture card with Tvheadend?
gsm42
Re: TBS6304 with Tvheadend
Postby steven » Tue May 12, 2020 6:16 pm
Hi Sir
Yea you can use TBS6304 with tvheadend as we are using virtual DVB-S tuner card you can check this
how to use with dvblast most the same
https://youtu.be/i3_tS_nA8Vg
kind Regards
Return to TBS6304 Quad HD HDMI capture card
