No RTSP OK after a teardown command
Postby ybuser » Mon Feb 10, 2020 9:53 pm
I would like to report a problem with TBS2604. After sending a TEARDOWN command to close a stream the TBS2604 doesn't answer with a RTSP/1.0 200 OK.
This cause problem with the VMS that i use because i cannot restart a stream right after closing the first stream.
Please advise.
Thank you
ybuser
Re: No RTSP OK after a teardown command
Postby daowei » Wed Feb 12, 2020 10:43 am
Just checked with our Encoder Engineer, she said need to check the code first about the "teardown to stop streaming". Any news, we'll upate to you. We're still on a vacation, when we back to work, we'll check.
Postby ybuser » Thu May 14, 2020 2:37 am
Any news regarding the teardown command.
thank you
ybuser
Return to TBS2604 / TBS2640 4K UHD HD H.265 & H.264 HDMI Video Encoder
