TBS 5925 problems with OpenPLI
Postby sleepy » Thu Jan 02, 2020 3:59 am
Dear all,
I am trying to use my TBS5925 with my new receiver, a GigaBlue UHD Quad 4K.
I used to have a DB 7025HD and for that OpenPLI stopped development at version 4, therefore no hope to make it work with that.
On the Gigablue I am running the latest 7.2 version and I installed the drivers from the plugins repository.
The 5925 is recognised by the system with no problems, so I was very confident in using it as tuner without problems.
Actually, the GigaBlue drives it with no problems. Channels are locked by the 5925 quickly and as expected, but I cannot see any picture or hear any sound from my TV.
Also, scanning reports no channels on the locked transponder.
Of course, I am testing with standard (no MIS) FTA channels, so there should be no problem.
I have been using the 5925 on a Windows laptop and with that everything works as expected (well, I have some problems getting some MIS channels, but that is another issue, to be corrected in a second phase).
I have tested also with the OpenPLI version shipped by GigaBlue themselves and with OpenATV, with the same partial results.
What am I doing wrong?
Is there a way to fix my problem?
Thank you in advance!
sleepy
