TBS6900 DVB Dual CI/CI+ PCI-e Card with Astra Cesbo Software
TBS6900 is a DVB network PCI-E card with two common interface slots, where you can insert 2 CAM inside to decrypt the pay channels.
TBS6900 DVB dual CI PCI-e card is a stand alone CI/CI+ a pcie card to use as a network resource.
Postby Jenny » Fri Dec 20, 2019 5:17 pm
Hi All,
Do you have any interest in using CAM CI/Ci+ module and smartcard to decrpt pay TV channels, and then remux and streaming out IP steams? If yes, TBS6900 DVB Dual CI PCI-E Card wil be your good choice for DVB-IP gatways, satellite Internet systems, home theaters and other solutions.
Here is live video " TBS6900 Dual CI/CI+ pcie stand alone card with Astra Cesbo Software" : https://youtu.be/xJ4b-Tds9w4
For more details on TBS6900, please check https://www.tbsiptv.com/tbs6900-dvb-dual-pci-e-card
Any further question or enquiry, feel free to e-mail us sales@tbsiptv.com
Best Regards,
Jenny Feng
Jenny
Re: TBS6900 DVB Dual CI/CI+ PCI-e Card with Astra Cesbo Soft
Postby lojasyst » Wed Apr 08, 2020 10:20 am
TBS 6590 does have a CI also, is possible to use TBS REMUX and other sofware with that card? if yes where should I download?
lojasyst
Postby zhangchao » Fri Apr 10, 2020 9:55 am
1. install driver for tbs6900
# wget http://www.tbsdtv.com/download/document ... 02.tar.bz2
#tar jxvf media_build-2020-01-02.tar.bz2
#cd media_build
#./install.sh
#reboot
2. install web for 6900
#wget http://www.tbsdtv.com/download/document ... .1.tar.bz2
#tar jxvf rootfs-6900-ubuntu-1.0.0.1.tar.bz2
#./update.sh
#reboot
default port is 80. input ip:80 in google or firefox broswer.
please add skype jack_2431 .
zhangchao
Postby sbilge » Tue Oct 13, 2020 10:25 pm
I buy 6900 and 6909 cards. Installed drivers and software.
[    6.303552] tbsci 0000:02:00.0: DVB: registering adapter 0 frontend 0 (tbs6900 dual ci)...
[    6.304044] tbsci 0000:02:00.0: DVB: registering adapter 0 frontend 0 (tbs6900 dual ci)...
[    9.106896] TBSECP3 driver 0000:03:00.0: DVB: registering adapter 1 frontend 0 (TurboSight TBS 6909x (Octa DVB-S/S2/S2X))...
[    9.193351] TBSECP3 driver 0000:03:00.0: DVB: registering adapter 2 frontend 0 (TurboSight TBS 6909x (Octa DVB-S/S2/S2X))...
[    9.315331] TBSECP3 driver 0000:03:00.0: DVB: registering adapter 3 frontend 0 (TurboSight TBS 6909x (Octa DVB-S/S2/S2X))...
[    9.437000] TBSECP3 driver 0000:03:00.0: DVB: registering adapter 4 frontend 0 (TurboSight TBS 6909x (Octa DVB-S/S2/S2X))...
[    9.558842] TBSECP3 driver 0000:03:00.0: DVB: registering adapter 5 frontend 0 (TurboSight TBS 6909x (Octa DVB-S/S2/S2X))...
[    9.680555] TBSECP3 driver 0000:03:00.0: DVB: registering adapter 6 frontend 0 (TurboSight TBS 6909x (Octa DVB-S/S2/S2X))...
[    9.802561] TBSECP3 driver 0000:03:00.0: DVB: registering adapter 7 frontend 0 (TurboSight TBS 6909x (Octa DVB-S/S2/S2X))...
[    9.924391] TBSECP3 driver 0000:03:00.0: DVB: registering adapter 8 frontend 0 (TurboSight TBS 6909x (Octa DVB-S/S2/S2X))...
/usr/bin/dvblast
/usr/bin/getadapter
/usr/bin/getfront
/usr/bin/getfront.sh
/usr/bin/kencastled
/usr/bin/lcd.sh
/usr/bin/runapache
/usr/bin/rundvblast
/usr/bin/tvserver
ASTRA Cesbo is working and channel is green. (I added &cas)
dvb://a001#pnr=16533&cas
But DVB Network CI interface does not work.
HTTP://IP:80 / 8080
I am using ubuntu 18.04.5 DELL workstation.
sbilge
Postby diabloss » Wed Oct 14, 2020 3:35 pm
sbilge Wrote:Hello,
HTTP://IP:80 / 8080
Hello
As you may know Astra Cesbo is a different entity/company than TBS , Cesbo mainly making software , TBS mainly making hardware.
However , astra cesbo with tbs6900 CI is in development beta stage testing , some CI work some don't work .... mostly because the support is not yet fully implemented.
According to their development team it will take a bit longer till we will get it as full release with support (version 5.7).
Meanwhile you can make use of your TBS6900 card via TBS provided specific software webui.
If you have difficulties getting the TBS webui software work with TBS6900 just contact support@tbsdtv.com and the tech team will assist and help you to get it working.
Best Regards
diabloss
Postby sbilge » Wed Oct 14, 2020 7:30 pm
I resolved my problem.
I started this services manually.
/usr/bin/runapache start
/usr/bin/tvserver start
Sincerely,
sbilge
Postby Nichcom » Tue Dec 29, 2020 9:19 pm
Hi Zhangchao,
Hi Steven,
The drivers are installed, no problem.
#lspci -vvnn | grep 6900 shows my device, as well #dmesg | grep frontend
But then, when installing the web, I stumbled:
#./update.sh
After executing this command #./update.sh, I see cp: cannot create directory '/lib/modules/4.18.0-041800-generic/kernel/drivers/'
I use https://releases.ubuntu.com/18.04/ubuntu-18.04.5-desktop-amd64.iso
Operation #uname -a issues Linux codec 5.4.0-58-generic #64~18.04.1-Ubuntu SMP Wed Dec 9 17:11:11 UTC 2020
As I understand it, you need to use (boot) the kernel 4.18.0 ?
You can use this https://teejeetech.in/ukuu/ , but every time at the beginning it is not very convenient to boot with the old kernel.
I tried this assembly as well http://www.tbsdtv.com/download/document/linux/media_build-2020-09-23.tar.bz2, but the same situation.
Or write exactly what version / build of the Ubuntu kernel I should use and where to download it EXACTLY with this kernel ?
Thank you in advance.
Nichcom
Postby zhangchao » Wed Dec 30, 2020 9:51 am
hi ,
if use (boot) the kernel 4.18.0 , there is no need to compile and install driver. (rootfs-6900-ubuntu-1.0.0.1.tar.bz2 include 6900's driver with 4.18.0)
please add skype jack_2431 or write email to support@tbsdtv.com.
best regards!
zhangchao
Postby Nichcom » Wed Dec 30, 2020 11:57 am
I can use absolutely any kernel and release Ubuntu.
But whatever I would not use now (except 4.18.0) I get this error cp: cannot create directory '/lib/modules/4.18.0-041800-generic/kernel/drivers/ when I execute the last command #./update.sh
But again, when loading with kernel 4.18.0 (to get around this error), when I start the web interface, I get the following errors:
And as a result, I do not see both cards in the web interface again.
Although through #dmesg | grep frontend they are visible.
p.s.
Before that, I install the driver (and they are installed for both my cards without problems under any releases and kernels) and see my cards as:
#wget http://www.tbsdtv.com/download/document ... 02.tar.bz2
#sudo rm -rf /lib/modules/`uname -r`/kernel/drivers/media/
#tar jxfv media_build-2020-01-02.tar.bz2
#cd media_build
#./install.sh
#reboot
Nichcom
Postby zhangchao » Thu Dec 31, 2020 11:20 am
hi ,
please add skype jack_2431 or write email to support@tbsdtv.com .
best regards!
zhangchao
Return to TBS6900 DVB Dual CI PCI-E Card
