blind scanning question #2
Postby tasoss » Fri Oct 11, 2019 12:52 am
Hello.
I would like to blind scan(using blscan2) H low,H high,V high,V low.
I want to use an adapter for each case(total 4 adapters).
By using a card like 6908(i think that when i have used 6903 i got the same results) the are missing transponders and the scan does not work as expected.
After contacting crazycat he told me that this is normal.
So my question is.
Which is the best way to blindscan all 4 cases the right way?
Install 4 different dvb cards?
It sounds a little bit overwhelming.
Any ideas?
Thanks!
tasoss
Re: blind scanning question #2
Postby tasoss » Fri Oct 14, 2022 12:26 am
Any ideas about that?
I mean what is the theory behind this that makes it impossible to scan in parallel with 4 cables and have accurate results?
The best option?
Use a 6903 and do V/H in different ports?
Thanks!
tasoss
Postby crazycat » Sat Oct 15, 2022 11:15 pm
you can use native TBS blindscan (disable HWControl in streamreader.ini)
Postby tasoss » Sun Oct 16, 2022 12:40 am
Hello crazycat and thanks for answering.
Well as far as i remember TBS' blindscanning is really slow.
Anyway thanks for answering.
tasoss
Return to Off topics
