Problem ONVIF in TBS 2603
Postby iie » Tue Oct 08, 2019 10:57 am
Hello
MilestoneXProtect® software is not capable to display image on state of ONVIF .The screen is displayed black.Also i checked it by DAHUA NVR .It could not identify device and display image and with onvif device manager is not work and detect.Please guide me
THANKS
ERROR in MILESTON VMS
ERROR in onvif device manager
iie
Re: Problem ONVIF in TBS 2603
Postby echomay » Wed Oct 09, 2019 2:55 pm
Please use "ONVIF TEST TOOL" to test it again.
And mail to me i will send you the manual.
My mail: echo@tbsdtv.com
echomay
Postby iie » Thu Oct 10, 2019 5:09 am
hello
push the play video not work show this error:
HTTP/1.1 400 Bad Request
Server: gSOAP/2.8
Content-Type: application/soap+xml; charset=utf-8
Content-Length: 3202
Connection: close
<?xml version="1.0" encoding="UTF-8"?>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:SOAP-ENC="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:wsa5="http://www.w3.org/2005/08/addressing" xmlns:c14n="http://www.w3.org/2001/10/xml-exc-c14n#" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd" xmlns:xenc="http://www.w3.org/2001/04/xmlenc#" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd" xmlns:xmime="http://tempuri.org/xmime.xsd" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:ns5="http://www.placeholder.org/ver10/tmp/schema" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsbf2="http://docs.oasis-open.org/wsrf/bf-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:wsr2="http://docs.oasis-open.org/wsrf/r-2" xmlns:daae="http://www.onvif.org/ver20/analytics/wsdl/AnalyticsEngineBinding" xmlns:dare="http://www.onvif.org/ver20/analytics/wsdl/RuleEngineBinding" xmlns:tan="http://www.onvif.org/ver20/analytics/wsdl" xmlns:decpp="http://www.onvif.org/ver10/events/wsdl/CreatePullPointBinding" xmlns:dee="http://www.onvif.org/ver10/events/wsdl/EventBinding" xmlns:denc="http://www.onvif.org/ver10/events/wsdl/NotificationConsumerBinding" xmlns:denf="http://www.onvif.org/ver10/events/wsdl/NotificationProducerBinding" xmlns:depp="http://www.onvif.org/ver10/events/wsdl/PullPointBinding" xmlns:depps="http://www.onvif.org/ver10/events/wsdl/PullPointSubscriptionBinding" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:depsm="http://www.onvif.org/ver10/events/wsdl/PausableSubscriptionManagerBinding" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:desm="http://www.onvif.org/ver10/events/wsdl/SubscriptionManagerBinding" xmlns:ns1="http://www.onvif.org/ver10/actionengine/wsdl" xmlns:ns2="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:ns4="http://www.placeholder.org/ver10/tmp/wsdl" xmlns:tad="http://www.onvif.org/ver10/analyticsdevice/wsdl" xmlns:tdis="http://www.onvif.org/ver10/display/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:trcv="http://www.onvif.org/ver10/receiver/wsdl" xmlns:trec="http://www.onvif.org/ver10/recording/wsdl" xmlns:trp="http://www.onvif.org/ver10/replay/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:tse="http://www.onvif.org/ver10/search/wsdl" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:snl="onvif/extend/snl/ver10/schema">
<SOAP-ENV:Body>
<SOAP-ENV:Fault>
<SOAP-ENV:Code>
<SOAP-ENV:Value>SOAP-ENV:Sender</SOAP-ENV:Value>
<SOAP-ENV:Subcode>
<SOAP-ENV:Value>ter:InvalidArgVal</SOAP-ENV:Value>
<SOAP-ENV:Subcode>
<SOAP-ENV:Value>ter:NoProfile</SOAP-ENV:Value>
</SOAP-ENV:Subcode>
</SOAP-ENV:Subcode>
</SOAP-ENV:Code>
<SOAP-ENV:Reason>
<SOAP-ENV:Text xml:lang="en">The requested ProfileToken does not exist.</SOAP-ENV:Text>
</SOAP-ENV:Reason>
</SOAP-ENV:Fault>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
iie
Postby echomay » Sat Oct 12, 2019 9:40 am
Did you recived my manual for this tool?
You need change the "Meida Profile" and then Play video.
echomay
