tbs 6514 problem
tbs 6514 problem
Postby bearbill » Mon Sep 23, 2019 10:23 am
tbs6514 have 4 tuner , one of the tuner not working. pls help
[    3.418023] TBSECP3 driver 0000:02:00.0: MAC address 00:22:ab:b1:9f:71
[    3.419579] gx1503 5-0030: read the chip id is 45
[    3.419581] gx1503 5-0030: Deceted the gx1503 chip
[    3.419643] i2c i2c-5: Added multiplexed i2c bus 18
[    3.427912] si2157 18-0060: Silicon Labs Si2147/2148/2157/2158 successfully attached
[    3.427933] TBSECP3 driver 0000:02:00.0: DVB: registering adapter 1 frontend 0 (Turbosight TBS 6514 (Quad DTMB))...
[    3.428218] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[    3.550028] TBSECP3 driver 0000:02:00.0: MAC address 00:22:ab:b1:9f:72
[    3.551709] gx1503 6-0030: read the chip id is 45
[    3.551710] gx1503 6-0030: Deceted the gx1503 chip
[    3.551794] i2c i2c-6: Added multiplexed i2c bus 19
[    3.559532] si2157 19-0060: Silicon Labs Si2147/2148/2157/2158 successfully attached
[    3.559580] TBSECP3 driver 0000:02:00.0: DVB: registering adapter 2 frontend 0 (Turbosight TBS 6514 (Quad DTMB))...
[    3.559665] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[    3.566892] [drm:intel_set_cpu_fifo_underrun_reporting [i915]] *ERROR* uncleared fifo underrun on pipe A
[    3.566920] [drm:intel_cpu_fifo_underrun_irq_handler [i915]] *ERROR* CPU pipe A FIFO underrun
[    3.566954] [drm:intel_set_pch_fifo_underrun_reporting [i915]] *ERROR* uncleared pch fifo underrun on pch transcoder A
[    3.566978] [drm:intel_pch_fifo_underrun_irq_handler [i915]] *ERROR* PCH transcoder A FIFO underrun
[    3.640223] vboxdrv: Found 8 processor cores
[    3.659688] vboxdrv: TSC mode is Invariant, tentative frequency 3605645529 Hz
[    3.659689] vboxdrv: Successfully loaded version 6.0.12 (interface 0x00290008)
[    3.682010] TBSECP3 driver 0000:02:00.0: MAC address 00:22:ab:b1:9f:73
[    3.683018] TBSECP3 driver 0000:02:00.0: i2c nack (5)
[    3.683029] gx1503: probe of 7-0030 failed with error -5
[    3.683032] TBSECP3 driver 0000:02:00.0: TBSECP3 frontend 3 attach failed
[    3.683034] TBSECP3 driver 0000:02:00.0: frontend attach failed
[    3.683157] TBSECP3 driver 0000:02:00.0: adapter3 attach failed
[    3.683160] TBSECP3 driver 0000:02:00.0: Turbosight TBS 6514 (Quad DTMB): PCI 0000:02:00.0, IRQ 73, MMIO 0xf7c00000
[    3.862777] VBoxNetFlt: Successfully started.
[    3.863878] VBoxNetAdp: Successfully started.
[    3.864991] VBoxPciLinuxInit
[    3.866525] vboxpci: IOMMU not found (not registered)
[    4.175220] gx1503 6-0030: downloading firmware from file 'dvb-demod-gx1503B.fw'
[    5.700307] si2157 19-0060: found a 'Silicon Labs Si2157-A30'
[    5.732188] si2157 19-0060: firmware version: 3.0.5
[    5.732289] TBSECP3 driver 0000:02:00.0: DVB: adapter 2 frontend 0 frequency 0 out of range (474000000..858000000)
[    5.743686] gx1503 5-0030: downloading firmware from file 'dvb-demod-gx1503B.fw'
[    7.111929] igb 0000:01:00.1 enp1s0f1: igb: enp1s0f1 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX
[    7.216185] igb 0000:01:00.3 enp1s0f3: igb: enp1s0f3 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX
[    7.216233] igb 0000:01:00.2 enp1s0f2: igb: enp1s0f2 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX
[    7.219704] IPv6: ADDRCONF(NETDEV_CHANGE): enp1s0f1: link becomes ready
[    7.286869] si2157 18-0060: found a 'Silicon Labs Si2157-A30'
[    7.312158] bond0: Enslaving enp1s0f1 as a backup interface with a down link
[    7.318979] si2157 18-0060: firmware version: 3.0.5
[    7.319093] TBSECP3 driver 0000:02:00.0: DVB: adapter 1 frontend 0 frequency 0 out of range (474000000..858000000)
[    7.323785] IPv6: ADDRCONF(NETDEV_CHANGE): enp1s0f2: link becomes ready
[    7.330131] gx1503 4-0030: downloading firmware from file 'dvb-demod-gx1503B.fw'
[    7.369974] IPv6: ADDRCONF(NETDEV_CHANGE): enp1s0f3: link becomes ready
[    7.419892] bond0: Enslaving enp1s0f2 as a backup interface with a down link
[    7.519929] bond0: Enslaving enp1s0f3 as a backup interface with a down link
[    7.627909] igb 0000:01:00.0 enp1s0f0: igb: enp1s0f0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX
[    7.628237] IPv6: ADDRCONF(NETDEV_CHANGE): enp1s0f0: link becomes ready
[    7.725921] bond0: Enslaving enp1s0f0 as a backup interface with a down link
[    8.001565] e1000e: eno1 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None
[    8.001686] IPv6: ADDRCONF(NETDEV_CHANGE): eno1: link becomes ready
[    8.894268] si2157 17-0060: found a 'Silicon Labs Si2157-A30'
[    8.924269] si2157 17-0060: firmware version: 3.0.5
[    8.924306] TBSECP3 driver 0000:02:00.0: DVB: adapter 0 frontend 0 frequency 0 out of range (474000000..858000000)
bearbill
Re: tbs 6514 problem
Postby steven » Tue Sep 24, 2019 10:08 am
which version of driver you are using ? and can you have a try change the PCI-E slot and try again ?
Postby bearbill » Tue Sep 24, 2019 11:53 am
tbs newest open source driver
os is ubuntu 18.04 kernel 5.0
the tuner can scan all the channel, but tuner#3 does not working
Is the card fail or the driver problems?
bearbill
Postby steven » Tue Sep 24, 2019 2:24 pm
From the log it is like one tuner is init failed , so please have a try change the PCI-E slot check whether is ok .
