TBS6590 and Cam module on Dutch encrypted services
Postby BlueSkyThinking » Mon Sep 09, 2019 3:47 pm
Can I please get some help with TBS6590 and cam module.
I cannot get the encrypted channels to work on 23.5 east Canal Digitaal.
I have the appropriate Cam module and card.
I am also the proud and very satisfied owner of a TBS6991, but that card is no longer supported in the more recent Ubuntu versions, so it is time to move on.
End goal is to use TBS6590 with MythTV, but for the speed of testing this card I am currently using mumudvb and dvblast.
Both seem to be very quick when making small configuration changes which hopefully helps in eliminating the issue I have
I have a desktop computer, with more than 2 partitions, 1 partition is on a virgin Ubuntu 18.04.3 LTS kernel 5.0.0-27-generic, to test the TBS6590 card and another on Virgin Ubuntu 14.04
kernel 4.4.0-142-generic for the TBS6991 card. Then I have installed the applications and drivers required for test.
For the TBS6590 I use the opensource driver download from 9 September 2019. The compile process does generate a number of warnings,
but seems to end OK.
The adapters are created after reboot, dmesg lists the frontend and reports that the cam is initialised.
dmesg output here:
[ 18.820578] TBSECP3 driver 0000:01:00.0: DVB: registering adapter 0 frontend 0 (TurboSight TBS 6590 DVB-S/S2 + 2xCI )...
[ 18.820609] TBSECP3 driver 0000:01:00.0: DVB: registering adapter 0 frontend 1 (Silicon Labs Si2183)...
[ 18.947720] TBSECP3 driver 0000:01:00.0: DVB: registering adapter 1 frontend 0 (TurboSight TBS 6590 DVB-S/S2 + 2xCI )...
[ 18.947766] TBSECP3 driver 0000:01:00.0: DVB: registering adapter 1 frontend 1 (Silicon Labs Si2183)...
[ 29.210010] TBSECP3 driver 0000:01:00.0: CA slot enabled for adapter1
[ 29.210011] dvb_ca_en50221: dvb_ca adapter 1: DVB CAM detected and initialised successfully
I therefore presume this is all OK, but given that I struggle getting the card to work this might contain a clue to the problem.
With TBS6991 on Ubuntu 14.04 -using the drivers from tbs-linux-drivers_v170330.zip- everything still works, which makes the problem more intriguing.
Swapping from one card to the another is done by physically swapping the cards after powerdown in the exact same PCIe slot, and reboot the appropriate OS
So what works on the TBS6590:
Cam is in inserted for all trials, green (TBS6590) led is lit, and dmesg reports successful initialisation of cam, and creation of frontends as mentioned above.
I can swing the dish with motor from 28.2 east to 23.5 east and vice versa using satmap.
I can with gnutv get to the cam data with: gnutv -adapter 1 -caslotnum 0 -cammenu
And I even believe to have seen that the expiry data has been updated whilst in the TBS6590
For 28.2 East FTA channels
I can receive and watch BBC Oxford as a DVBS channel with success
I can receive and watch BBC ONE HD as a DVBS-2 channel with success
For 23.5 East
I can receive and watch OCKO TV (FTA) as a DVBS channel with success.
The above successes are both done with a mumudvb and dvblast.
For mumdvb config in include the OCKO one as an example:
Start file contents of Ocko_single.mumudvb_v2.conf top
#DVB Card specifics
#Ensure that demux and the dvr are symbolic linked to 1 e.g a demux1 and dvr1 must exist.
card=1
tuner=1
#cam_support=1
#this is weird, cam0 seems to at least respond to a certain degree
#cam_number=0
#Streaming specifics
#disable multicast  THIS PARAMETER HAS CHANGED NAME FROM multicast TO multicast_ipv4
multicast_ipv4=0
#enable unicast
unicast=1
#listen at all addresses
ip_http=192.168.1.189
#default port 4242
port_http=4242
#Transponder specifics
freq=12168
pol=v
srate=27500
delivery_system=DVBS
modulation=QPSK
#coderate=3/4
#rolloff=35
#channel specifics
new_channel
name=PQ2
unicast_port=8001
pids=54 53 257
#pids=261  #video pid, audio pid, pmt pid
#pmt_pid=xxx   #only for scrambled channels
#new_channel if more then one
End file contents of Ocko_single.mumudvb_v2.conf bottom
And the Command line for Mumudvb looks then like this:
/usr/local/bin/mumudvb -d -c "./Ocko_single.mumudvb_v2.conf"
I can play the channel on VLC using this:
vlc -> playlists -> right click -> open media -> open network -> http://192.168.1.189:4242/playlist_port.m3u -> ENTER
Or as an alternative with a DVBlast config file like the one below. OCKO one as an example
Start file contents of ocko_dvblast.conf top
239.255.0.1:8001 1 5201
End file contents of ocko_dvblast.conf bottom
The Command line for DVBlast look like this:
dvblast -a 1 -n 1 -f 12168000 -s 27500000 -v 13 -C -c "./ocko_dvblast.conf"
I can play channel on VLC using this :
vlc -> playlists -> right click -> open media -> open network -> rtp://239.255.0.1:8001 -> ENTER
Two things that I have noticed are:
1: using the old femon application from dvbtools. there is a significant repeatable drop in signal strength.
(The cable and devices between LNB and card have not changed at all, and are almost undisturbed, reconnecting one f-connector when swapping the cards)
TBS6991 indicates signal stength of B4** to C5** in hex values and a SNR of F0** to FF**
TBS6590 gives noticeable lower signal strength. 82** to 8c** in hex values and a SNR of b6** to c0** in hex values.
This could well be that the values are obtained in a different way and hence this is not a real issue
2:It feels that the TBS6991 is more solid in its performance and behaviour. Could well be subjective.
What does not work on TBS6590
Mumudvb config file looks like this for the SBS6 encrypted channel
Start file contents of SBS6_single.mumudvb_v3.conf top
#DVB Card specifics
card=1
tuner=1
cam_support=1
#this is weird, cam0 seems to atleast respond to a certain degree
cam_number=0
multicast_ipv4=0
#enable unicast
unicast=1
#default port 4242
port_http=4242
freq=11739
pol=v
srate=29900
delivery_system=DVBS2
modulation=8PSK
coderate=2/3
rolloff=35
#channel specifics
new_channel
name=PQ3
unicast_port=8001
pids=2490 526 106
pmt_pid=2490
cam_ask=1
End file contents of SBS6_single.mumudvb_v3.conf bottom
command line for mumudvb looks like this:
/usr/local/bin/mumudvb -d -c "./SBS6_single.mumudvb_v3.conf"
DVBlast config file looks like this for the SBS6 channel.
Start file contents of SBS6_dvblast.conf top
239.255.0.1:8001 1 6090
End file contents of SBS6_dvblast.conf bottom
command line used for dvblast:
dvblast -a 1 -n 1 -f 11739000 -s 29900000 -m psk_8 -F 23 -v 13 -C -c "./SBS6_dvblast.conf"
Using dvblast whilst the TBS6590 is inplay.
Gives a constant stream of discontinuity errors on the Dvblast terminal screen.
warning: TS discontinuity on pid 526 expected_cc 1 got 2 (H.264/14496-10 video (MPEG-4/AVC), sid 6090)
warning: TS discontinuity on pid 526 expected_cc 5 got 6 (H.264/14496-10 video (MPEG-4/AVC), sid 6090)
warning: TS discontinuity on pid 106 expected_cc 6 got 7 (13818-3 audio (MPEG-2), sid 6090)
warning: TS discontinuity on pid 526 expected_cc 7 got 8 (H.264/14496-10 video (MPEG-4/AVC), sid 6090)
warning: TS discontinuity on pid 42 expected_cc 13 got 14 (H.222.0/13818-1 PES private data, sid 6090)
warning: TS discontinuity on pid 526 expected_cc 12 got 13 (H.264/14496-10 video (MPEG-4/AVC), sid 6090)
With Mumudvb it starts and does report that the channel is fully de-crypted, but when trying to play the stream
Looking at the messages in VLC I see a constant stream of discontinuity error messages,
ts error: libdvbpsi (PSI decoder): TS discontinuity (received 3, expected 2) for PID 18
ts error: libdvbpsi (PSI decoder): TS discontinuity (received 7, expected 6) for PID 18
warnings and debug gives even more messages.
The video output itself looks blotched and a large part of the screen is grey blocks.
The top of the screen the first 5% has the least distortion.
signal strength with femon looks like this:
rpq@rpq-OptiPlex-960:~$ femon -a 1 -f 1
FE: Silicon Labs Si2183 (DVBS)
status SCVYL | signal 8cf0 | snr b02c | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status SCVYL | signal 8cf0 | snr acf8 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
I can, if beneficial, provide similar information for NPO1, different frequency, and polarisation. The result is the same.
I can receive and watch SBS6, NPO1 and others on the TBS6991.
One thing to note is that for the TBS6991 card I have to set Ask-cam in Mumudvb config file, which seems to indicate
that the channels - although scrambled - are advertised in the stream as FTA. That is how I read the mumudvb manual, on that specific option.
I apologise for the extensive explanation of what I have done. I hope that the comparison helps to indicate
what I am missing in the set up to get the TBS6590 to work as well or better than the TBS6991 does.
I fully expect and hope that you would require more specific detail, and you can get access to this box if that would help
in diagnosing the problem.
Your help and further analyses is very much appreciated, because I am at a dead end at this moment.
BlueSkyThinking
Re: TBS6590 and Cam module on Dutch encrypted services
Postby xiaocao » Mon Sep 16, 2019 5:20 pm
hi ,
please set this pids and test
pmt_pid =
service_id =
pids = pcr_pid video_pid audio_pid
xiaocao
Postby BlueSkyThinking » Tue Sep 17, 2019 5:52 pm
Thanks for responding to the issue that I raised.
Going on the suggestion I presumed you were referring to the mumudvb config file.
I implemented your suggestion, adding service_id=6090 to the mumu configuaration file.
this section
#channel specifics
new_channel
name=PQ3
unicast_port=8001
pids=2490 526 106
pmt_pid=2490
cam_ask=1
becomes this
#channel specifics
new_channel
name=PQ3
unicast_port=8001
service_id=6090
pids=2490 526 106
pmt_pid=2490
cam_ask=1
Unfortunately that did not resolve the issue.
Starting mumdvb lists this. Indicating succesfull descramble
Deb1:  TS:  GOOD service_id for PMT 2490 and channel "PQ3"
Info:  CAM:  Received new PMT - sending to CAM...
Info:  CAM:  CA PMT (ADDED) sent for channel 0 : "PQ3"
Info:  Main:  Channel "PQ3" is now partially unscrambled (43% of scrambled packets). Card 1
Info:  Main:  Channel "PQ3" is now fully unscrambled (0% of scrambled packets). Card 1
Opening VLC to watch the stream, I get the same top of 5% of the screen best visible, not perfect, the rest grey-ish blocks.
On the message screen of VLC there are the same type of errors listed at a constant high rate.
Snippet of the sort of errors below
ts error: libdvbpsi (PSI decoder): TS discontinuity (received 9, expected 8) for PID 18
ts error: libdvbpsi (PSI decoder): TS discontinuity (received 14, expected 13) for PID 18
ts error: libdvbpsi (PSI decoder): TS discontinuity (received 12, expected 11) for PID 18
ts error: libdvbpsi (PSI decoder): TS discontinuity (received 4, expected 3) for PID 18
ts error: libdvbpsi (PSI decoder): TS discontinuity (received 0, expected 15) for PID 18
Compiling the open source driver is challenging, it fails a lot on the make step for me.
I am most likely to be successful in compiling over the weekend in a strange way.
I managed to catch some of the warnings I get.
The last successful compile with warnings from scratch - that is including a complete new download from git - was from Saturday September 14th 2019
I moved from Ubuntu 18.04 to 19.04 in the hope that it could resolve the issue. Unfortunately it did not.
These are the modules that raise a warning during the make step.
Going on the names, some seem to relate to TBS drivers or driver components.
    tbs_priv.c
    tbsecp3-dvb.c
    tbsecp3-asi.c
    tbs_pcie.c
    tbs_pcie-sdi.c
    tbsmod.c
and a few others.
I don't know which modules I need for the TBS6590 card, so this might well be unimportant.
I can list the warnings if you believe this would be helpful.
I hope you will give further assistance to determine the cause of the issue.
Please let me know if you need more specific information.
Thanks.
BlueSkyThinking
Postby BlueSkyThinking » Sat Sep 21, 2019 1:06 am
Hi Xiaocao,
Not sure whether something is happening in the background within TBS with this issue. I am hoping that you are still looking finding the source of the issue. After all it is strange that all of my set up works on an older Ubuntu version with TBS6991 but it fails on TBS6950 with Ubuntu 19.04 or 18.04.
More in general: Is there somebody else out there that has TBS6950 working with Canal Digitaal the Dutch encrypted channels on 23.5 East. Would like to compare config's to understand what is stopping mine from working. Anybody want to give a hand....
Thanks.
BlueSkyThinking
Postby BlueSkyThinking » Sun Oct 06, 2019 8:15 pm
Team,
I have now followed the instruction to raise this as a driver problem.
There have been a reasonable amount of views of the post, and only 1 response on possible configuration issues have been suggested.
That suggestion was followed with no change in status.
The short version of the problem is that the Cam module plus subscription card do not decrypt the channels on 23.5 East.
Whilst the same Cam module plus subscription card using a TBS6991 works.
The choice for the TBS6590 was made following your suggestion in this post. viewtopic.php?f=69&t=25070&p=54308#p54302
Where I outline:
"I need to move to 18.04 to stay current, and I need diseqc rotor and CI CAM."
Read the posts preceding post 5 for more detail on my attempts to get this card and Cam module to work.
dmesg and lspci log attached as a zipped file here:
dmesg_lspci_LinVer.zip
dmesg_lspci_LinVer
(22.28 KiB) Downloaded 3006 times
linux distribution here:
Linux rpq-OptiPlex-960 5.3.1 #1 SMP Sun Sep 22 12:01:06 BST 2019 x86_64 x86_64 x86_64 GNU/Linux
Awaiting your response to your findings from the detail provided.
BlueSkyThinking
Postby ajtsx02 » Thu Nov 07, 2019 9:53 pm
Hello guys,
I think I'm having the same issue trying to decode italian television on Hotbird 13E.
I have installed a TBS6590 on my pc running ubuntu 18.04 server.
I'm using tvheadend on this server.
I was able to tune the muxes and to discover services (meaning channels) available on this satellite position.
After inserting the cam and the subscription card I've got green light from TBS6590 and dmesg report a correct initialasation; also tvheadend in Configuration > DVB Inputs > TV adapters shows: "ca0: CAM tivusat CI+ (module ready)"
Free to air channels works correctly, encrypted italian tv channels does't get decoded.
The same cam and subscription card works perfectly on my philips tv which has a sat tuner included.
The cam I'm using was bought on Amazon Italy and is this one:
https://www.amazon.it/Scheda-CAM-compat ... 253&sr=8-6
I will write an email to tbs as soon as possible for assistance.
Regards,
Andrea
ajtsx02
Postby Klaus » Thu Nov 07, 2019 10:17 pm
ajtsx02 Wrote:....
initialisation; also tvheadend in Configuration > DVB Inputs > TV adapters shows: "ca0: CAM tivusat CI+ (module ready)"
Regards,
Andrea
Hi Andrea,
I'm not an expert but what about the CI+ issue, the slot of the TBS6590 is not a CI+ slot (only CI) - could that be the problem? If you try to decrypt CI+ channels it will not work.
klaus
Klaus
Postby ajtsx02 » Fri Nov 08, 2019 9:52 pm
Thank you Klaus for the reply,
you pointed me to a question I didn't think about!
I have started looking to understand if those channels require CI+, but I have to admit it is very difficult to get the answer.
Italian channels on hotbird 13E are managed by tivusat.it, on their site they state that you need a certified tivusat cam, but still it is obscure to know if CI+ is mandatory.
Does anybody know how to discover if a channel require a ci+ cam to be decoded? maybe a particular parameter? few sites list a lot of parameters of every satellite, but no one give me the information if CI+ is mandatory.
I'm still investigating.
Regards,
Andrea
ajtsx02
Postby DVB » Mon Nov 11, 2019 12:57 am
Tivusat requires CI+, it won't work that way.
There were some attempts to enable CI+ support, but I've never heard of any details nor seen that working: viewtopic.php?f=86&t=25089
An alternative is to use only card without CAM in TBS 3102 Phoenix card reader and oscam, but configuration is not easy.
And now you're watching 8K:
KKKKKKKK
DVB
