[ Moderator Control Panel ]
by evangelion69 » Mon Sep 09, 2019 12:36 am
Hello. On standard LNB everything is working fine. Now I have unicable LNB (inverto) and want to connect two cables from it direct to tbs6902 card via inverto splitter. Specs told me this card have unicable suport. When I changed tvheadend option from standard lnb to unicable nothing is happening. Any solutions?
evangelion69
by steven » Fri May 22, 2020 2:58 pm
Hi Sir
For 6902 if you want to use unicale ,both port need signal input , if you just want 1 cable input for 2 tuners it do not support
only the 6909 or 6909x support with 1 cable input for 8 tuners
