Is there any way to use two TBS-6205 Quad-Tuners together?
Postby anton2003 » Fri Sep 06, 2019 9:11 pm
Hi, i am interested to buy this product: https://www.tbs-technology.de/shop/DVB-T-T2-C-Quad-Tuner-PCIe-Terrestrial-or-cable-TV-Card-TBS-6205
NOTE: I only need to watch or record DVB-T-T2 channels (freeview channels)!
I live in Cyprus.
a) Is this product compatible with the freeview channels in my country?
b) Is this product compatible with my pc? My PC model is: HP ProDesk 400 G4 MT x64-based PC.
If yes, can I purchase and use two TBS-6205 Quad-Tuners in order to connect them together and watch or record up to EIGHT(8) TV programmes at a time? I only need to watch or record DVB-T-T2 channels (freeview channels).
If yes, how can i connect them together?
Please advise!
anton2003
Re: Is there any way to use two TBS-6205 Quad-Tuners togethe
Postby steven » Sat Oct 12, 2019 9:33 am
Hi Sir
For your questions:
For DVB-T/T2 totally ok
it is ok ,and you can using 2x6205 at the same time and if you want to watch and record at the same time recommend try with linux
tvheadend software which is easy to use
kind Regards
