TBS6590 cannot tune satellite
Postby Klaus » Thu Aug 29, 2019 6:11 pm
I have a configuration for mumudvb to fetch a transponder from Hotbird S13E0. This configuration works for TBS6909 which is also connected to a DiSEqC switch. But when I apply the configuration to the TBS6590 card no signal is found?
delivery_system=DVBS2
TBS6590: card=0, tuner=1
TBS6909: card=4, tuner=0
freq=11347
pol=v
srate=22000
autoconfiguration=full
sat_number=2
switch_type=C
diseqc_time=15
diseqc_repeat=1
Any idea why the TBS6590 cannot tune ?
log 6909:
Info: Main: Streaming. Freq 11373000.000000
Info: Tune: Using DVB card "TurboSight TBS 6909 DVB-S/S2 " tuner 0
Info: Tune: Tuning DVB-S to Freq: 1623000 kHz, Transp frequency: 11373000.000000 , LO frequency 9750000 kHz Pol:H Srate=27500000, LNB number: 1
Info: Tune: LNB voltage 18V
Info: Tune: Sending DISEQC
Info: Tune: DISEQC: Setting Tone OFF
Info: Tune: DISEQC: Setting Voltage and wait 15 ms
Info: Tune: DISEQC: Send CMD and wait 15 ms
Info: Tune: DISEQC: Send BURST and wait 15 ms
Info: Tune: DISEQC: Set TONE back and wait 15 ms
Info: Tune: Re-sending DISEQC
Info: Tune: DISEQC SETTING SUCCEEDED - Frequency: 1623000
Info: Tune: Tuning With DVB-API version 5. delivery system : 6
Info: Tune: FE_STATUS:
Info: Tune: FE_HAS_SIGNAL : found something above the noise level
Info: Tune: FE_HAS_CARRIER : found a DVB signal
Info: Tune: FE_HAS_VITERBI : FEC is stable
Info: Tune: FE_HAS_SYNC : found sync bytes
Info: Tune: FE_HAS_LOCK : everything's working...
Info: Tune: Event: Frequency: 11373000 (or 8127000)
Info: Tune: SymbolRate: 27500000
Info: Tune: FEC_inner: 3
Info: Tune: Bit error rate: 0
Info: Tune: Signal strength: 38704
Info: Tune: SNR: 47888
Info: Main: Card 4, tuner 0 tuned
main 0x7ffc388ea570
Info: Common chan: Looking through all services to update their filters
Info: Unicast: We open the Master http socket for address 127.0.0.1:8009
Info: Common chan: We open the channel 0 multicast IPv4 socket address 239.110.40.21:4444
Info: Common chan: We open the channel 1 multicast IPv4 socket address 239.110.40.22:4444
Info: Common chan: We open the channel 2 multicast IPv4 socket address 239.110.40.23:4444
Info: Common chan: We open the channel 3 multicast IPv4 socket address 239.110.40.24:4444
Info: Common chan: We open the channel 4 multicast IPv4 socket address 239.110.40.25:4444
Info: Common chan: We open the channel 5 multicast IPv4 socket address 239.110.40.26:4444
Info: Common chan: We open the channel 6 multicast IPv4 socket address 239.110.40.27:4444
Info: Common chan: We open the channel 7 multicast IPv4 socket address 239.110.40.28:4444
Info: Common chan: We open the channel 8 multicast IPv4 socket address 239.110.40.29:4444
Info: Common chan: We open the channel 9 multicast IPv4 socket address 239.110.40.30:4444
Info: Common chan: We open the channel 10 multicast IPv4 socket address 239.110.40.31:4444
Info: Autoconf: Autoconfiguration is now ready to work for you !
Info: Autoconf: The CAT version changed
Info: Autoconf: New CAT we force SDT update after all sections seen
Info: Autoconf: The PAT version changed, channels have changed
Info: Autoconf: New PAT we force SDT update after all sections seen
WARN: Autoconf: Channel 0 SID 501 Force PMT update
WARN: Autoconf: Channel 1 SID 504 Force PMT update
WARN: Autoconf: Channel 2 SID 506 Force PMT update
WARN: Autoconf: Channel 3 SID 507 Force PMT update
WARN: Autoconf: Channel 4 SID 508 Force PMT update
WARN: Autoconf: Channel 5 SID 509 Force PMT update
WARN: Autoconf: Channel 6 SID 510 Force PMT update
WARN: Autoconf: Channel 7 SID 530 Force PMT update
WARN: Autoconf: Channel 8 SID 532 Force PMT update
WARN: Autoconf: Channel 9 SID 533 Force PMT update
WARN: Autoconf: Channel 10 SID 534 Force PMT update
WARN: Autoconf: Channel 11 SID 1303 Force PMT update
Info: Autoconf: The SDT version changed, channels description have changed
Info: Autoconf: We update the channel names
Info: Autoconf: We update the channel status
Info: Autoconf: Looking through all channels to see if they are ready for streaming
Info: Autoconf: We update the channel filters
Info: Autoconf: We update the channel networking
Info: Autoconf: We update the channel CAM support
Info: Autoconf: Diffusion 11 channels
Info: Autoconf: Channel number : 0, service id 501 name : "Iran International HD"
Info: Autoconf: Multicast4 ip : 239.110.40.21:4444
Info: Autoconf: Unicast : Channel accessible via the master connection, 127.0.0.1:8009
Info: Autoconf: Channel number : 1, service id 504 name : "NASA TV HD"
Info: Autoconf: Multicast4 ip : 239.110.40.22:4444
Info: Autoconf: Channel number : 2, service id 506 name : "RUDAW HD"
Info: Autoconf: Multicast4 ip : 239.110.40.23:4444
Info: Autoconf: Channel number : 3, service id 507 name : "WAAR HD"
Info: Autoconf: Multicast4 ip : 239.110.40.24:4444
Info: Autoconf: Channel number : 4, service id 508 name : "Kurdistan 24 HD"
Info: Autoconf: Multicast4 ip : 239.110.40.25:4444
Info: Autoconf: Channel number : 5, service id 509 name : "TV&TV"
Info: Autoconf: Multicast4 ip : 239.110.40.26:4444
Info: Autoconf: Channel number : 6, service id 510 name : "Parole di Vita"
Info: Autoconf: Multicast4 ip : 239.110.40.27:4444
Info: Autoconf: Channel number : 7, service id 530 name : "World Fashion Channel"
Info: Autoconf: Multicast4 ip : 239.110.40.28:4444
Info: Autoconf: Channel number : 8, service id 532 name : "Tesory Channel"
Info: Autoconf: Multicast4 ip : 239.110.40.29:4444
Info: Autoconf: Channel number : 9, service id 533 name : "NHK WORLD-JAPAN"
Info: Autoconf: Multicast4 ip : 239.110.40.30:4444
Info: Autoconf: Channel number : 10, service id 534 name : "Iraqia News HD"
Info: Autoconf: Multicast4 ip : 239.110.40.31:4444
log 6590
Info: Tune: Using DVB card "Silicon Labs Si2183" tuner 1
Many thanks in advance for some suggestion - can i check if the card is broken?
klaus
Klaus
Re: TBS6590 cannot tune satellite
Postby steven » Thu Aug 29, 2019 6:23 pm
For 6590 need to set the module please have a try with dvblast using -n 1 or tvheadend check whether is well
Postby Klaus » Thu Aug 29, 2019 7:51 pm
I set module (frontend number) with tuner=1 for mumudvb, otherwise it wouldn't work at all:
Info: Main: ========== End of configuration, MuMuDVB version 2.1.0_20180909_mumudvb2 is starting ==========
Info: Tune: Using DVB card "TurboSight TBS 6590 DVB-S/S2 + 2xCI " tuner 0
WARN: Tune: The delivery system does not fit with the card frontend type (DVB-T/T2 ISDBT).
WARN: Tune: We ask the card to change the delivery system (multi frontend cards).
ERRO: Tune: FE_SET_PROPERTY failed : Invalid argument
Info: Main: Tuning issue, card 0
Info: Main: Closing cleanly. Error 7
steven Wrote:Hi
Klaus
Postby steven » Fri Aug 30, 2019 11:39 am
For the mumudvb you need to set the frontend value not the tuner value ,
you can set this value
delivery_system (the delivery system used (can be DVBT DVBT2 DVBS DVBS2 DVBC_ANNEX_AC DVBC_ANNEX_B ATSC ISDBT))
http://mumudvb.net/documentation/asciidoc/mumudvb-2.1.0/README_CONF.html#_parameters_concerning_all_modes_terrestrial_satellite_cable_atsc
or Please have a try with tvheadend or dvblast
Postby Klaus » Fri Aug 30, 2019 2:55 pm
Hi steven,
yes indeed and if you read the mumudvb manual than you would see that itis exactly what the tuner-parameter is meant for - setting the correct frontend-value
mumudvb -l gives you:
Info: DVB: ==================================
Info: DVB: DVB CARDS LISTING
Info: DVB: =========== Card 0 - Tuner 1 ===========
Info: DVB: Frontend : Silicon Labs Si2183
Info: DVB: Satellite (DVB-S) card
Info: DVB: Frequency: 950000 kHz to 2150000 kHz
Info: DVB: Symbol rate: 1000 k symbols/s to 45000 k symbols/s
Info: DVB:
Info: DVB: =========== Card 0 - Tuner 0 ===========
Info: DVB: Frontend : TurboSight TBS 6590 DVB-S/S2 + 2xCI
Info: DVB: Terrestrial (DVB-T) card
Info: DVB: Frequency: 42000 kHz to 870000 kHz
Info: DVB:
Since I haven't installed neither tvheadend nor dvblast I currently cannot test otherwise.
Klaus
Postby steven » Tue Sep 03, 2019 2:30 pm
Hi Klaus
Thanks for your update , please try with dvblast or tvheadend which support set the module and if you still can not
best setupt the remote we can remote check for you , you can send email to our support#tbsdtv.com
Postby Klaus » Tue Sep 03, 2019 7:09 pm
Hi steven,
thanks for the offer - I double checked with dvblast - problem is the timing between diseqc-commands. dvblast waits 100ms, if i set that value within mumudvb i get also a lock.
thx,
klaus
Klaus
Postby tonygables » Wed Sep 25, 2019 8:45 pm
Hi, I have the same issue with TBS6590. I am using a 16 port multiswitch (4 satellites). I cannot tune to satellites 2-3-4 using TBS6590.
TBS6909 which is installed on the same server works well. I am using dvblast on Ubuntu 16.04.
# dmesg | grep -i tbsversion
[ 12.129118] tbsversion 2019-05-21
adapter0 and adapter1 ==> TBS6590
adapter2 -- adapter9 ==> TBS6909
dvblast -a 2 -f 10992000 -s 27500000 -v 13 -S 2 ===> Locked (TBS6909)
dvblast -a 1 -f 10992000 -s 27500000 -v 13 -S 2 -n 1 ==> Unlocked (TBS6590)
dvblast -a 1 -f 12015000 -s 27500000 -v 18 -S 2 -n 1 ==> Locks to 12015MHz transponder on satellite-1
So it means TBS6590 is not sending the diseqc command to the multiswitch???
Any help appreciated.
tonygables
Postby Klaus » Fri Nov 01, 2019 10:22 pm
I guess its a timing problem of the driver, seems TBS6590 is very sensitive to timing between diseqc commands. Since I'm not working with dvblast you should try out different tools, like mumudvb if you can get a lock.
klaus
Klaus
Postby tonygables » Wed Sep 30, 2020 2:25 pm
Klaus Wrote:Hi,
klaus
Hi, can you please tell me which parameter you are setting for mumudvb to work? I couldn't get lock with dvblast.
tonygables
