TBS5580 performances
Postby Kemon » Sun Aug 25, 2019 12:08 pm
Hi all, I am planning to buy TBS5580 tommorow (26 aug).
1. Does TBS5580 good on crazyscan?
2. Scanning on TBS5580 with crazyscan, is it real time spectrum or swept?
3. Does it need good cpu processor or graphic card?
thanks.
Kemon
Re: TBS5580 performances
Postby steven » Thu Aug 29, 2019 2:27 pm
Hi Sir
TBS5580 support crazyscan more information you can find here:
https://sourceforge.net/p/crazyscan/wiki/Info/
If just scan normal CPU is well , if you want to play the HD channels you can try with a normal GPU card too
Postby Kemon » Mon Sep 02, 2019 10:15 am
steven Wrote:Hi Sir
thanks sir. I made the call. item will be deliver this Wednesday.. hopefully....
Kemon
Return to General discussion
