Tbs 8510 pro ddns
TBS8520 and TBS8510
Tbs 8510 pro ddns
Postby a343 » Fri Aug 02, 2019 4:08 pm
I greet you all here in the
forum .... I have a problem with the stream,
The stream is ok locally
but with the ddns airs
he not the ports are ok on tcp ... have on the 8510pro kylone 2.2.1ee
Please help... :roll:
a343
Re: Tbs 8510 pro ddns
Postby steven » Mon Aug 05, 2019 11:45 am
Hi Sir
Inside your router you can set the right port (4750) map to the 8510pro server then you can use the DDNS to access the stream
Postby a343 » Thu Aug 08, 2019 10:34 pm
Sir thank you it worked great.
a343
Postby pritisikka » Thu Sep 05, 2019 12:55 pm
Great post
pritisikka
Return to TBS Transcoding solution
