Problem 6909
Problem 6909
Postby hugouske » Fri Aug 02, 2019 4:40 am
I bought the TBS 6909 a few weeks ago, but I can't make it work.
I try to use it in DVB Dream, but it does not find any channels.
I tested with another program and nothing.
The same message always appears: No channels found.
The signal from the card always remains the same, regardless of whether the cable is connected or not and even changing the satellite to one that has no cabling remains the same 60%.
Is it a problem on the board?
Thank you.
hugouske
Re: Problem 6909
Postby steven » Mon Aug 05, 2019 11:47 am
What about your singal connect way to 6909 , please have a try read the guide first
and please provide more information send to our support@tbsdtv.com
Re: Problem 6909
Postby Username » Mon Apr 13, 2020 1:00 am
With my 5580 DVB Dream dont show me any channel to.
With the OEM TBS Version of dvbviewer if works?!
I use Sat. What does must set in DVB Dream?!
Username
Re: Problem 6909
Postby steven » Mon Apr 13, 2020 9:59 am
When you using 5580 with DVBDream DVB-S signal what about your DVBDream scan parameters ?
please send email to our support@tbsdtv.com provide your scan parameters let us have a check with it
Re: Problem 6909
Postby satesco » Mon Apr 13, 2020 5:58 pm
If you're working with DVB Dream for the first time,it's a good thing before you set up the satellite and the band(Ku,C,Ka) you want to scan:Options->Diseqc->Add Satellite(Properties->LNB Type).
I hope that's the only problem and not the card :?:
satesco
