Problem compiling drivers for tbs 6902 on Debian stretch
Postby Boronsbruder » Sun Jul 28, 2019 8:59 pm
After the last kernel update 4.9.0-9-amd64 i tried to comile the drivers for my 6902.
MAKE stopped throwing out errors. So i switched back to Linux ZEROSERVER 4.9.0-8-amd64 #1 SMP Debian 4.9.144-3.1 (2019-02-19) x86_64 GNU/Linux
After rebooting my 6902 cards were correctly recognized by the tvheadend-server.
But now when i try to compile the drivers again i get the same errors as i got when trying to compile with the new kernel...
root@ZEROSERVER:~/tbsdriver/tbs_git# git clone https://github.com/tbsdtv/media_build.git
Klone nach 'media_build' ...
remote: Enumerating objects: 195, done.
remote: Counting objects: 100% (195/195), done.
remote: Compressing objects: 100% (92/92), done.
remote: Total 5661 (delta 121), reused 158 (delta 103), pack-reused 5466
Empfange Objekte: 100% (5661/5661), 1.11 MiB | 209.00 KiB/s, Fertig.
Löse Unterschiede auf: 100% (4090/4090), Fertig.
root@ZEROSERVER:~/tbsdriver/tbs_git# git clone --depth=1 https://github.com/tbsdtv/linux_media.git -b latest ./media
Klone nach './media' ...
remote: Enumerating objects: 68829, done.
remote: Counting objects: 100% (68829/68829), done.
remote: Compressing objects: 100% (64995/64995), done.
remote: Total 68829 (delta 5781), reused 14172 (delta 3010), pack-reused 0
Empfange Objekte: 100% (68829/68829), 180.81 MiB | 1.38 MiB/s, Fertig.
Löse Unterschiede auf: 100% (5781/5781), Fertig.
Checke Dateien aus: 100% (64843/64843), Fertig.
root@ZEROSERVER:~/tbsdriver/tbs_git/media_build# make dir DIR=../media
make -C linux/ dir DIR="../../media"
make[1]: Verzeichnis „/root/tbsdriver/tbs_git/media_build/linux“ wird betreten
rm -rf drivers include sound mm .patches_applied .linked_dir .git_log.md5 git_log kernel_version.h
Searching in ../../media/Makefile for kernel version.
./use_dir.pl ../../media
sync file: include/uapi/linux/meye.h
sync file: include/uapi/linux/cec-funcs.h
sync file: include/uapi/linux/v4l2-subdev.h
sync file: include/uapi/linux/videodev2.h
sync file: include/uapi/linux/media-bus-format.h
sync file: include/linux/pci_ids.h
sync file: include/linux/dma/xilinx_dma.h
sync file: include/trace/events/pwc.h
sync file: include/uapi/linux/v4l2-mediabus.h
sync file: include/trace/events/v4l2.h
sync file: include/trace/events/vb2.h
sync file: include/uapi/linux/media.h
sync file: include/uapi/linux/smiapp.h
sync file: include/linux/kconfig.h
sync file: include/uapi/linux/uvcvideo.h
sync file: sound/pci/bt87x.c
sync file: include/uapi/linux/xilinx-v4l2-controls.h
sync file: include/linux/of_graph.h
sync file: include/linux/via-core.h
sync file: include/uapi/linux/lirc.h
sync file: include/uapi/linux/max2175.h
sync file: include/uapi/linux/v4l2-common.h
sync file: include/linux/overflow.h
sync file: include/linux/dma-fence.h
sync file: include/misc/altera.h
sync file: include/uapi/linux/cec.h
sync file: include/linux/hdmi.h
sync file: include/uapi/linux/ivtv.h
sync file: include/uapi/linux/ivtvfb.h
sync file: include/linux/ti_wilink_st.h
sync file: include/linux/fixp-arith.h
sync file: include/linux/mmc/sdio_ids.h
sync file: include/sound/aci.h
sync file: include/uapi/linux/usb/video.h
sync file: include/uapi/linux/v4l2-controls.h
sync file: include/linux/dma-buf.h
sync file: include/uapi/linux/v4l2-dv-timings.h
sync dir: include/linux/platform_data/media/
sync dir: include/media/
sync dir: drivers/misc/altera-stapl/
sync dir: drivers/staging/media/
sync dir: include/dt-bindings/media/
sync dir: drivers/media/
sync dir: include/uapi/linux/dvb/
make[1]: Verzeichnis „/root/tbsdriver/tbs_git/media_build/linux“ wird verlassen
root@ZEROSERVER:~/tbsdriver/tbs_git/media_build# make allyesconfig
make -C /root/tbsdriver/tbs_git/media_build/v4l allyesconfig
make[1]: Verzeichnis „/root/tbsdriver/tbs_git/media_build/v4l“ wird betreten
No version yet, using 4.9.0-8-amd64
make[2]: Entering directory '/root/tbsdriver/tbs_git/media_build/linux'
Syncing with dir ../../media
Applying patches for kernel 4.9.0-8-amd64
patch -s -f -N -p1 -i ../backports/api_version.patch
patch -s -f -N -p1 -i ../backports/pr_fmt.patch
patch -s -f -N -p1 -i ../backports/debug.patch
patch -s -f -N -p1 -i ../backports/drx39xxj.patch
patch -s -f -N -p1 -i ../backports/v5.1_vm_map_pages.patch
patch -s -f -N -p1 -i ../backports/v5.0_ipu3-cio2.patch
patch -s -f -N -p1 -i ../backports/v4.20_access_ok.patch
patch -s -f -N -p1 -i ../backports/v4.18_fwnode_args_args.patch
patch -s -f -N -p1 -i ../backports/v4.18_add_map_atomic.patch
patch -s -f -N -p1 -i ../backports/v4.17_proc_create_single.patch
patch -s -f -N -p1 -i ../backports/v4.17_i2c_check_num_msgs.patch
patch -s -f -N -p1 -i ../backports/v4.15_pmdown_time.patch
patch -s -f -N -p1 -i ../backports/v4.14_saa7146_timer_cast.patch
patch -s -f -N -p1 -i ../backports/v4.14_module_param_call.patch
patch -s -f -N -p1 -i ../backports/v4.13_remove_nospec_h.patch
patch -s -f -N -p1 -i ../backports/v4.13_drmP.patch
patch -s -f -N -p1 -i ../backports/v4.12_revert_solo6x10_copykerneluser.patch
patch -s -f -N -p1 -i ../backports/v4.11_drop_drm_file.patch
patch -s -f -N -p1 -i ../backports/v4.10_sched_signal.patch
patch -s -f -N -p1 -i ../backports/v4.10_fault_page.patch
patch -s -f -N -p1 -i ../backports/v4.10_refcount.patch
patch -s -f -N -p1 -i ../backports/v4.9_mm_address.patch
patch -s -f -N -p1 -i ../backports/v4.9_dvb_net_max_mtu.patch
Patched drivers/media/dvb-core/dvbdev.c
Patched drivers/media/v4l2-core/v4l2-dev.c
Patched drivers/media/rc/rc-main.c
make[2]: Leaving directory '/root/tbsdriver/tbs_git/media_build/linux'
./scripts/make_kconfig.pl /lib/modules/4.9.0-8-amd64/build /lib/modules/4.9.0-8-amd64/source 1
Preparing to compile for kernel version 4.9.0
cd <your kernel dir>
WARNING: This is the V4L/DVB backport tree, with experimental drivers
         backported to run on legacy kernels from the development tree at:
                http://git.linuxtv.org/media-tree.git.
         It is generally safe to use it for testing a new driver or
         feature, but its usage on production environments is risky.
         Don't use it in production. You've been warned.
VIDEO_MUX: Requires at least kernel 4.13.0
VIDEO_CROS_EC_CEC: Requires at least kernel 4.19.0
RADIO_WL128X: Requires at least kernel 4.13.0
VIDEO_TDA1997X: Requires at least kernel 4.15.0
VIDEO_IMX214: Requires at least kernel 4.10.0
VIDEO_IMX258: Requires at least kernel 4.10.0
VIDEO_IMX319: Requires at least kernel 4.10.0
VIDEO_IMX355: Requires at least kernel 4.10.0
VIDEO_OV2680: Requires at least kernel 4.10.0
VIDEO_OV5670: Requires at least kernel 4.10.0
VIDEO_OV7251: Requires at least kernel 4.10.0
VIDEO_OV772X: Requires at least kernel 4.18.0
VIDEO_OV8856: Requires at least kernel 4.10.0
VIDEO_MT9V111: Requires at least kernel 4.10.0
VIDEO_AK7375: Requires at least kernel 4.10.0
VIDEO_DW9714: Requires at least kernel 9.255.255
VIDEO_DW9807_VCM: Requires at least kernel 4.10.0
VIDEO_I2C: Requires at least kernel 4.17.0
VIDEO_ST_MIPID02: Requires at least kernel 4.10.0
I2C_BCM2048: Requires at least kernel 4.10.0
VIDEO_IPU3_IMGU: Requires at least kernel 9.255.255
./scripts/fix_kconfig.pl
make[1]: Verzeichnis „/root/tbsdriver/tbs_git/media_build/v4l“ wird verlassen
Boronsbruder
Re: Problem compiling drivers for tbs 6902 on Debian stretch
Postby Boronsbruder » Sun Jul 28, 2019 9:01 pm
root@ZEROSERVER:~/tbsdriver/tbs_git/media_build# make -j4
scripts/make_makefile.pl
./scripts/make_myconfig.pl
[ ! -f "./config-mycompat.h" ] && echo "/* empty config-mycompat.h */" > "./config-mycompat.h" || true
make -C firmware prep
perl scripts/make_config_compat.pl /lib/modules/4.9.0-8-amd64/source ./.myconfig ./config-compat.h
creating symbolic links...
make[2]: Entering directory '/root/tbsdriver/tbs_git/media_build/v4l/firmware'
make[2]: Nothing to be done for 'prep'.
make[2]: Leaving directory '/root/tbsdriver/tbs_git/media_build/v4l/firmware'
make -C firmware
make[2]: Nothing to be done for 'default'.
Kernel build directory is /lib/modules/4.9.0-8-amd64/build
make -C ../linux apply_patches
Patches for 4.9.0-8-amd64 already applied.
make -C /lib/modules/4.9.0-8-amd64/build SUBDIRS=/root/tbsdriver/tbs_git/media_build/v4l  modules
make[2]: Entering directory '/usr/src/linux-headers-4.9.0-8-amd64'
  CC [M]  /root/tbsdriver/tbs_git/media_build/v4l/msp3400-driver.o
gcc-6: error: /usr/src/linux-headers-4.9.0-8-common/drivers/media/i2c: No such file or directory
gcc-6: error: /usr/src/linux-headers-4.9.0-8-common/drivers/media/dvb-frontends/: No such file or directory
gcc-6: error: /usr/src/linux-headers-4.9.0-8-common/drivers/media/tuners/: No such file or directory
gcc-6: error: /usr/src/linux-headers-4.9.0-8-common/drivers/media/tuners: No such file or directory
gcc-6: error: /usr/src/linux-headers-4.9.0-8-common/drivers/media/common/b2c2/: No such file or directory
gcc-6: error: /usr/src/linux-headers-4.9.0-8-common/drivers/media/dvb-frontends: No such file or directory
gcc-6: error: /usr/src/linux-headers-4.9.0-8-common/drivers/media/common/siano: No such file or directory
gcc-6: error: /usr/src/linux-headers-4.9.0-8-common/drivers/media/common: No such file or directory
gcc-6: error: /usr/src/linux-headers-4.9.0-8-common/drivers/media/dvb-frontends/cxd2880: No such file or directory
/usr/src/linux-headers-4.9.0-8-common/scripts/Makefile.build:309: die Regel für Ziel „/root/tbsdriver/tbs_git/media_build/v4l/msp3400-driver.o“ scheiterte
make[5]: *** [/root/tbsdriver/tbs_git/media_build/v4l/msp3400-driver.o] Fehler 1
/usr/src/linux-headers-4.9.0-8-common/Makefile:1546: die Regel für Ziel „_module_/root/tbsdriver/tbs_git/media_build/v4l“ scheiterte
make[4]: *** [_module_/root/tbsdriver/tbs_git/media_build/v4l] Fehler 2
Makefile:152: recipe for target 'sub-make' failed
make[3]: *** [sub-make] Error 2
Makefile:8: recipe for target 'all' failed
make[2]: *** [all] Error 2
make[2]: Leaving directory '/usr/src/linux-headers-4.9.0-8-amd64'
Makefile:51: die Regel für Ziel „default“ scheiterte
make[1]: *** [default] Fehler 2
Makefile:26: die Regel für Ziel „all“ scheiterte
make: *** [all] Fehler 2
Where is the problem?
Is it me? :D
Ah and by the way headers are installed...
root@ZEROSERVER:~/tbsdriver/tbs_git/media_build/v4l# apt-get install linux-headers-4.9.0-8-amd64
Paketlisten werden gelesen... Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen.... Fertig
linux-headers-4.9.0-8-amd64 ist schon die neueste Version (4.9.144-3.1).
0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
Boronsbruder
Postby steven » Mon Jul 29, 2019 9:24 am
Please have a try with this package:
#wget http://www.tbsdtv.com/download/document/linux/media_build-2019-06-27.tar.bz2
#tar jxvf media_build-2019-06-27.tar.bz2
#cd media_build
#./install.sh
#reboot
Postby Boronsbruder » Fri Aug 02, 2019 6:41 pm
Thx m8!!
I needed to download and compile it twice. Second time it compiled and tvheadend is running fine!!
Boronsbruder
Postby steven » Mon Aug 05, 2019 11:45 am
Thanks for your update
Postby Boronsbruder » Sun Nov 01, 2020 5:34 pm
Hello again!
Up to 4.9.0-12 your manual did work. With 4.9.0-14 it stopped working.
Compiling with GIT still doesn't work...
Boronsbruder
Postby steven » Mon Nov 02, 2020 2:37 pm
please have a try with this new package :
# wget http://www.tbsdtv.com/download/document/linux/media_build-2020-09-23.tar.bz2
#tar jxvf media_build-2020-09-23.tar.bz2
#cd media_build
#./install.sh
#reboot
kind Regards
Postby Boronsbruder » Sun Nov 08, 2020 2:42 pm
Thx for the reply, but it didn't work... (see file ... *err* can't attach log file...)
Abhängigkeitsbaum wird aufgebaut....
libproc-processtable-perl ist schon die neueste Version (0.53-2).
libelf-dev ist schon die neueste Version (0.168-1).
1 out of 1 hunk FAILED -- saving rejects to file include/media/v4l2-clk.h.rej
Applying patches for kernel 4.9.0-14-amd64
4 9 0
dvb-demod-avl6882.fw
dvb-demod-drxk-pctv.fw
dvb-demod-gx1503B.fw
dvb-demod-mn88472-02.fw
dvb-demod-mn88473-01.fw
dvb-demod-si2168-01.fw
dvb-demod-si2168-02.fw
dvb-demod-si2168-a20-01.fw
dvb-demod-si2168-a30-01.fw
dvb-demod-si2168-b40-01.fw
dvb-demod-si2183-b60-01.fw
dvb-fe-bcm3510-01.fw
dvb-fe-cx24116.fw
dvb-fe-cx24117.fw
dvb-fe-drxj-mc-1.0.8.fw
dvb-fe-drxj-mc-vsb-1.0.8.fw
dvb-fe-drxj-mc-vsb-qam-1.0.8.fw
dvb-fe-ds3000.fw
dvb-fe-ds300x.fw
dvb-fe-ds3103.fw
dvb-fe-mxl5xx.fw
dvb-fe-or51132-qam.fw
dvb-fe-or51132-vsb.fw
dvb-fe-or51211.fw
dvb-fe-rs6000.fw
dvb-fe-tda10045.fw
dvb-fe-tda10046.fw
dvb-fe-tda10048-1.0.fw
dvb-fe-tda10071.fw
dvb-fe-xc4000-1.4.1.fw
dvb-fe-xc5000-1.6.114.fw
dvb-fe-xc5000c-4.1.30.7.fw
dvb-tuner-si2158-a20-01.fw
dvb-usb-avertv-a800-02.fw
dvb-usb-bluebird-01.fw
dvb-usb-dib0700-1.20.fw
dvb-usb-dibusb-5.0.0.11.fw
dvb-usb-dibusb-6.0.0.8.fw
dvb-usb-dtt200u-01.fw
dvb-usb-dw2101.fw
dvb-usb-dw2102.fw
dvb-usb-dw2104.fw
dvb-usb-dw3101.fw
dvb-usb-id5301.fw
dvb-usb-id5520se.fw
dvb-usb-id5580.fw
dvb-usb-id5590.fw
dvb-usb-it9135-01.fw
dvb-usb-it9135-02.fw
dvb-usb-p1100.fw
dvb-usb-p1100-old.fw
dvb-usb-p7500.fw
dvb-usb-pctv-400e-01.fw
dvb-usb-pctv-450e-01.fw
dvb-usb-pctv-452e-01.fw
dvb-usb-s620.fw
dvb-usb-s630.fw
dvb-usb-s660.fw
dvb-usb-sb340.fw
dvb-usb-SkyStar_USB_HD_FW_v17_63.HEX.fw
dvb-usb-tbs5520-01.fw
dvb-usb-tbsqbox-dvbc.fw
dvb-usb-tbsqbox-id2601.fw
dvb-usb-tbsqbox-id5220.fw
dvb-usb-tbsqbox-id5520.fw
dvb-usb-tbsqbox-id5680.fw
dvb-usb-tbsqbox-id5880.fw
dvb-usb-tbsqbox-id5881.fw
dvb-usb-tbsqbox-id5910.fw
dvb-usb-tbsqbox-id5920.fw
dvb-usb-tbsqbox-id5921.fw
dvb-usb-tbsqbox-id5922.fw
dvb-usb-tbsqbox-id5923.fw
dvb-usb-tbsqbox-id5925.fw
dvb-usb-tbsqbox-id5927.fw
dvb-usb-tbsqbox-id5928.fw
dvb-usb-tbsqbox-id5980.fw
dvb-usb-terratec-h5-drxk.fw
dvb-usb-terratec-h7-az6007.fw
dvb-usb-terratec-h7-drxk.fw
dvb-usb-tt-s2400-01.fw
dvb-usb-umt-010-02.fw
dvb-usb-vp702x-01.fw
dvb-usb-vp7045-01.fw
dvb-usb-wt220u-01.fw
dvb-usb-wt220u-02.fw
sms1xxx-hcw-55xxx-dvbt-02.fw
sms1xxx-hcw-55xxx-isdbt-02.fw
sms1xxx-nova-a-dvbt-01.fw
sms1xxx-nova-b-dvbt-01.fw
sms1xxx-stellar-dvbt-01.fw
v4l-cx231xx-avcore-01.fw
v4l-cx23418-apu.fw
v4l-cx23418-cpu.fw
v4l-cx23418-dig.fw
v4l-cx23885-avcore-01.fw
v4l-cx23885-enc-broken.fw
v4l-cx23885-enc.fw
v4l-cx25840.fw
make -C /root/tbsdriver/tbs_4.9.0-14/media_build/v4l distclean
make[1]: Verzeichnis „/root/tbsdriver/tbs_4.9.0-14/media_build/v4l“ wird betreten
No version yet, using 4.9.0-14-amd64
rm -f *~ *.o *.ko .*.o.cmd .*.ko.cmd *.mod.c av7110_firm.h fdump \
   config-compat.h Module.symvers Module.markers modules.order \
   *.unsigned .*.ko.unsigned.cmd
make -C firmware clean
make[2]: Entering directory '/root/tbsdriver/tbs_4.9.0-14/media_build/v4l/firmware'
make[2]: Nothing to be done for 'clean'.
make[2]: Leaving directory '/root/tbsdriver/tbs_4.9.0-14/media_build/v4l/firmware'
rm -f .version .*.o.flags .*.o.d *.mod.gcno Makefile.media \
   Kconfig Kconfig.kern .config .config.cmd .myconfig \
   .kconfig.dep config-mycompat.h
rm -rf .tmp_versions .tmp*.ver .tmp*.o .*.gcno .cache.mk
rm -f scripts/lxdialog scripts/kconfig
make -C firmware distclean
make[2]: Nothing to be done for 'distclean'.
make[1]: Verzeichnis „/root/tbsdriver/tbs_4.9.0-14/media_build/v4l“ wird verlassen
make -C /root/tbsdriver/tbs_4.9.0-14/media_build/v4l stagingconfig
make[2]: Entering directory '/root/tbsdriver/tbs_4.9.0-14/media_build/linux'
Can't find ../../media/Makefile at ./use_dir.pl line 287.
Makefile:132: recipe for target 'apply_patches' failed
make[2]: *** [apply_patches] Error 2
make[2]: Leaving directory '/root/tbsdriver/tbs_4.9.0-14/media_build/linux'
Makefile:391: die Regel für Ziel „stagingconfig“ scheiterte
make[1]: *** [stagingconfig] Fehler 2
Makefile:26: die Regel für Ziel „stagingconfig“ scheiterte
make: *** [stagingconfig] Fehler 2
V4L drivers building...
Updating/Creating .config
Boronsbruder
Postby Boronsbruder » Sun Nov 08, 2020 3:14 pm
CEC_CH7322: Requires at least kernel 4.16.0
CEC_CROS_EC: Requires at least kernel 9.255.255
V4L2_H264: Requires at least kernel 9.255.255
VIDEO_IPU3_CIO2: Requires at least kernel 9.255.255
VIDEO_OMAP3: Requires at least kernel 9.255.255
VIDEO_XILINX: Requires at least kernel 4.10.0
VIDEO_XILINX_CSI2RXSS: Requires at least kernel 4.13.0
VIDEO_MAX9286: Requires at least kernel 4.19.0
VIDEO_HI556: Requires at least kernel 4.10.0
VIDEO_IMX219: Requires at least kernel 4.10.0
VIDEO_IMX290: Requires at least kernel 4.10.0
VIDEO_OV2740: Requires at least kernel 4.17.0
VIDEO_OV5675: Requires at least kernel 4.10.0
VIDEO_OV772X: Requires at least kernel 4.19.0
VIDEO_OV9650: Requires at least kernel 4.19.0
VIDEO_RDACM20: Requires at least kernel 4.10.0
VIDEO_DW9714: Requires at least kernel 4.10.0
VIDEO_DW9768: Requires at least kernel 4.10.0
SND_BT87X: Requires at least kernel 9.255.255
INTEL_ATOMISP: Requires at least kernel 9.255.255
VIDEO_HANTRO: Requires at least kernel 9.255.255
VIDEO_ROCKCHIP_VDEC: Requires at least kernel 9.255.255
perl scripts/make_config_compat.pl /lib/modules/4.9.0-14-amd64/source ./.myconfig ./config-compat.h
make -C firmware
Kernel build directory is /lib/modules/4.9.0-14-amd64/build
make -C /lib/modules/4.9.0-14-amd64/build M=/root/tbsdriver/tbs_4.9.0-14/media_build/v4l  modules
make[2]: Entering directory '/usr/src/linux-headers-4.9.0-14-amd64'
  CC [M]  /root/tbsdriver/tbs_4.9.0-14/media_build/v4l/msp3400-driver.o
gcc-6: error: /usr/src/linux-headers-4.9.0-14-common/drivers/media/i2c: No such file or directory
gcc-6: error: /usr/src/linux-headers-4.9.0-14-common/drivers/media/dvb-frontends/: No such file or directory
gcc-6: error: /usr/src/linux-headers-4.9.0-14-common/drivers/media/tuners/: No such file or directory
gcc-6: error: /usr/src/linux-headers-4.9.0-14-common/drivers/media/tuners: No such file or directory
gcc-6: error: /usr/src/linux-headers-4.9.0-14-common/drivers/media/common/b2c2/: No such file or directory
gcc-6: error: /usr/src/linux-headers-4.9.0-14-common/drivers/media/dvb-frontends: No such file or directory
gcc-6: error: /usr/src/linux-headers-4.9.0-14-common/drivers/media/common/siano: No such file or directory
gcc-6: error: /usr/src/linux-headers-4.9.0-14-common/drivers/media/common: No such file or directory
gcc-6: error: /usr/src/linux-headers-4.9.0-14-common/drivers/media/dvb-frontends/cxd2880: No such file or directory
/usr/src/linux-headers-4.9.0-14-common/scripts/Makefile.build:309: die Regel für Ziel „/root/tbsdriver/tbs_4.9.0-14/media_build/v4l/msp3400-driver.o“ scheiterte
make[5]: *** [/root/tbsdriver/tbs_4.9.0-14/media_build/v4l/msp3400-driver.o] Fehler 1
/usr/src/linux-headers-4.9.0-14-common/Makefile:1560: die Regel für Ziel „_module_/root/tbsdriver/tbs_4.9.0-14/media_build/v4l“ scheiterte
make[4]: *** [_module_/root/tbsdriver/tbs_4.9.0-14/media_build/v4l] Fehler 2
make[2]: Leaving directory '/usr/src/linux-headers-4.9.0-14-amd64'
Boronsbruder
Postby Boronsbruder » Sun Nov 08, 2020 3:15 pm
V4L drivers installing...
make -C /root/tbsdriver/tbs_4.9.0-14/media_build/v4l install
Hmm... distro kernel with a non-standard place for module backports detected.
Please always prefer to use vanilla upstream kernel with V4L/DVB
I'll try to remove old/obsolete LUM files from /lib/modules/4.9.0-14-amd64//updates/dkms:
find: warning: Unix filenames usually don't contain slashes (though pathnames do).  That means that '-name 'pci/css_2401_system/hive/ia_css_isp_params.ko'' will probably evaluate to false all the time on this system.  You might find the '-wholename' test more useful, or perhaps '-samefile'.  Alternatively, if you are using GNU grep, you could use 'find ... -print0 | grep -FzZ 'pci/css_2401_system/hive/ia_css_isp_params.ko''.
find: warning: Unix filenames usually don't contain slashes (though pathnames do).  That means that '-name 'pci/css_2401_system/host/ibuf_ctrl.ko'' will probably evaluate to false all the time on this system.  You might find the '-wholename' test more useful, or perhaps '-samefile'.  Alternatively, if you are using GNU grep, you could use 'find ... -print0 | grep -FzZ 'pci/css_2401_system/host/ibuf_ctrl.ko''.
find: warning: Unix filenames usually don't contain slashes (though pathnames do).  That means that '-name 'pci/css_2401_system/host/csi_rx.ko'' will probably evaluate to false all the time on this system.  You might find the '-wholename' test more useful, or perhaps '-samefile'.  Alternatively, if you are using GNU grep, you could use 'find ... -print0 | grep -FzZ 'pci/css_2401_system/host/csi_rx.ko''.
find: warning: Unix filenames usually don't contain slashes (though pathnames do).  That means that '-name 'pci/css_2401_system/host/isys_irq.ko'' will probably evaluate to false all the time on this system.  You might find the '-wholename' test more useful, or perhaps '-samefile'.  Alternatively, if you are using GNU grep, you could use 'find ... -print0 | grep -FzZ 'pci/css_2401_system/host/isys_irq.ko''.
find: warning: Unix filenames usually don't contain slashes (though pathnames do).  That means that '-name 'pci/css_2401_system/host/isys_dma.ko'' will probably evaluate to false all the time on this system.  You might find the '-wholename' test more useful, or perhaps '-samefile'.  Alternatively, if you are using GNU grep, you could use 'find ... -print0 | grep -FzZ 'pci/css_2401_system/host/isys_dma.ko''.
find: warning: Unix filenames usually don't contain slashes (though pathnames do).  That means that '-name 'pci/atomisp_gmin_platform.ko'' will probably evaluate to false all the time on this system.  You might find the '-wholename' test more useful, or perhaps '-samefile'.  Alternatively, if you are using GNU grep, you could use 'find ... -print0 | grep -FzZ 'pci/atomisp_gmin_platform.ko''.
find: warning: Unix filenames usually don't contain slashes (though pathnames do).  That means that '-name 'pci/css_2401_system/hive/ia_css_isp_states.ko'' will probably evaluate to false all the time on this system.  You might find the '-wholename' test more useful, or perhaps '-samefile'.  Alternatively, if you are using GNU grep, you could use 'find ... -print0 | grep -FzZ 'pci/css_2401_system/hive/ia_css_isp_states.ko''.
find: warning: Unix filenames usually don't contain slashes (though pathnames do).  That means that '-name 'pci/css_2401_system/hive/ia_css_isp_configs.ko'' will probably evaluate to false all the time on this system.  You might find the '-wholename' test more useful, or perhaps '-samefile'.  Alternatively, if you are using GNU grep, you could use 'find ... -print0 | grep -FzZ 'pci/css_2401_system/hive/ia_css_isp_configs.ko''.
find: warning: Unix filenames usually don't contain slashes (though pathnames do).  That means that '-name 'pci/css_2401_system/host/isys_stream2mmio.ko'' will probably evaluate to false all the time on this system.  You might find the '-wholename' test more useful, or perhaps '-samefile'.  Alternatively, if you are using GNU grep, you could use 'find ... -print0 | grep -FzZ 'pci/css_2401_system/host/isys_stream2mmio.ko''.
Boronsbruder
