Only one shot tuning in the channel
Postby tomi » Tue Jun 18, 2019 6:41 pm
HI,
I have a server with 5 TBS 6904 cards and one TBS 6205.
Ubuntu 18.04.2
4.15.0-51-generic
I just used the install.sh script. I had to fix an error in v4l ;
sudo nano netup_unidvb_i2c.c
( I added line :
int num=0;
This card is irrelevant to my TBS issue)
to make it compile.
The installation then went okay.
Now the problem is, I get only one shot tuning in the channel see below.
When I hit Ctrl-C and try the same command, it can't lock anymore.
This happens on every DVB-S tuner in the server.
After reboot it works again once.
This sounds like a bug in firmware / driver to me?
tomi@satbox8:~$ szap -a 4 -c asd Canale5
reading channels from file 'asd'
zapping to 1 'Canale5':
sat 0, frequency = 11432 MHz V, symbolrate 29900000, vpid = 0x04ba, apid = 0x04bc sid = 0x007a
using '/dev/dvb/adapter4/frontend0' and '/dev/dvb/adapter4/demux0'
Version: 5.11 FE_CAN { DVB-S + DVB-S2 }
status 1f | signal fa7c | snr 0000 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
status 1f | signal f9c6 | snr cd00 | ber 00001cb2 | unc 00000000 | FE_HAS_LOCK
status 1f | signal f8e2 | snr cd00 | ber 00000000 | unc 00000000 | FE_HAS_LOCK
^C
status 00 | signal fb8d | snr 0000 | ber 03ffffff | unc 00000000 |
status 00 | signal fbba | snr 0000 | ber 03ffffff | unc 00000000 |
I also tried with mumudvb and it has the same issue.
There are no warnings in dmesg during these issues.
lspci |grep -i mul
01:00.0 Multimedia controller: TBS Technologies DVB-S2 4 Tuner PCIe Card
02:00.0 Multimedia controller: TBS Technologies DVB-S2 4 Tuner PCIe Card
03:00.0 Multimedia controller: TBS Technologies DVB-S2 4 Tuner PCIe Card
04:00.0 Multimedia controller: TBS Technologies DVB-S2 4 Tuner PCIe Card
05:00.0 Multimedia controller: TBS Technologies DVB-S2 4 Tuner PCIe Card
07:00.0 Multimedia controller: TBS Technologies DVB-S2 4 Tuner PCIe Card
tomi
Re: Only one shot tuning in the channel
Postby steven » Fri May 22, 2020 3:30 pm
hi sir
after press ctrl+c , please check again the process whether stop ,if it have not stop
then you can not use it any more , possible try with dvblast ?
Return to DVB-S2 Quad Tuner PCIe Card TBS6904
