Install TBS6928se on Centos 7 Error make
Postby wandeu » Sat May 25, 2019 5:36 pm
[root@ServerDT linux-tbs-drivers]# uname -a
Linux ServerDT 3.10.0-957.12.2.el7.x86_64 #1 SMP Tue May 14 21:24:32 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
[root@ServerDT linux-tbs-drivers]# make
make -C /root/tbs/linux-tbs-drivers/v4l
make[1] : on entre dans le répertoire « /root/tbs/linux-tbs-drivers/v4l »
creating symbolic links...
make -C firmware prep
make[2]: Entering directory `/root/tbs/linux-tbs-drivers/v4l/firmware'
make[2]: Leaving directory `/root/tbs/linux-tbs-drivers/v4l/firmware'
make -C firmware
make[2]: Nothing to be done for `default'.
Kernel build directory is /lib/modules/3.10.0-957.12.2.el7.x86_64/build
make -C /lib/modules/3.10.0-957.12.2.el7.x86_64/build SUBDIRS=/root/tbs/linux-tbs-drivers/v4l modules
make[2]: Entering directory `/usr/src/kernels/3.10.0-957.12.2.el7.x86_64'
CC [M] /root/tbs/linux-tbs-drivers/v4l/tuner-xc2028.o
In file included from <command-line>:0:0:
/root/tbs/linux-tbs-drivers/v4l/compat.h: In function 'snd_card_create':
/root/tbs/linux-tbs-drivers/v4l/compat.h:662:2: warning: passing argument 1 of 'snd_card_new' makes pointer from integer without a cast [enabled by default]
*card = snd_card_new(idx, id, module, extra_size);
In file included from /root/tbs/linux-tbs-drivers/v4l/compat.h:217:0,
include/sound/core.h:239:5: note: expected 'struct device *' but argument is of type 'int'
int snd_card_new(struct device *parent, int idx, const char *xid,
/root/tbs/linux-tbs-drivers/v4l/compat.h:662:2: warning: passing argument 2 of 'snd_card_new' makes integer from pointer without a cast [enabled by default]
include/sound/core.h:239:5: note: expected 'int' but argument is of type 'const char *'
/root/tbs/linux-tbs-drivers/v4l/compat.h:662:2: warning: passing argument 3 of 'snd_card_new' from incompatible pointer type [enabled by default]
include/sound/core.h:239:5: note: expected 'const char *' but argument is of type 'struct module *'
/root/tbs/linux-tbs-drivers/v4l/compat.h:662:2: warning: passing argument 4 of 'snd_card_new' makes pointer from integer without a cast [enabled by default]
include/sound/core.h:239:5: note: expected 'struct module *' but argument is of type 'int'
/root/tbs/linux-tbs-drivers/v4l/compat.h:662:2: error: too few arguments to function 'snd_card_new'
include/sound/core.h:239:5: note: declared here
make[3]: *** [/root/tbs/linux-tbs-drivers/v4l/tuner-xc2028.o] Erreur 1
make[2]: *** [_module_/root/tbs/linux-tbs-drivers/v4l] Error 2
make[2]: Leaving directory `/usr/src/kernels/3.10.0-957.12.2.el7.x86_64'
make[1]: *** [default] Erreur 2
make[1] : on quitte le répertoire « /root/tbs/linux-tbs-drivers/v4l »
make: *** [all] Erreur 2
I need help
lspci output
30:00.0 Multimedia controller: Philips Semiconductors SAA7160 (rev 03)
Subsystem: Device 6928:0002
Physical Slot: 1-1
Interrupt: pin A routed to IRQ 5
Region 0: Memory at f0600000 (64-bit, non-prefetchable) [size=1M]
Address: 0000000000000000 Data: 0000
ExtTag- AttnBtn- AttnInd- PwrInd- RBE- FLReset- SlotPowerLimit 0.000W
DevCtl: Report errors: Correctable- Non-Fatal- Fatal+ Unsupported-
LnkCap: Port #1, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <4us, L1 <64us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
LnkCtl: ASPM Disabled; RCB 128 bytes Disabled- CommClk-
tbs-linux-drivers_v170330.zip the driver that I use
wandeu
Re: Install TBS6928se on Centos 7 Error make
Postby xiaocao » Mon May 27, 2019 10:05 am
hi ,
please download driver from https://www.tbsiptv.com/download/common ... 160405.zip and re-install.
best regards!
xiaocao
Postby wandeu » Wed May 29, 2019 5:12 pm
./v4l/tbs-x86_64.sh
make clean
make distclean
make
/root/tbs16405/linux-tbs-drivers/v4l/compat.h:662:2: error: too few arguments to function 'snd_card_new'
In file included from /root/tbs16405/linux-tbs-drivers/v4l/compat.h:217:0,
make[3]: *** [/root/tbs16405/linux-tbs-drivers/v4l/tuner-xc2028.o] Erreur 1
make[2]: *** [_module_/root/tbs16405/linux-tbs-drivers/v4l] Error 2
make[1] : on quitte le répertoire « /root/tbs16405/linux-tbs-drivers/v4l »
The same error
wandeu
Postby steven » Wed May 29, 2019 5:58 pm
Sorry about this is it possible try ubuntu with kernel under 4.10 such as 4.6 4.8
then use this pacakge :
#sudo rm -rf /lib/modules/`uname -r`/kernel/drivers/media/
1.wget http://www.tbsiptv.com/download/common/tbs-linux-drivers_v170330.zip
2.unzip tbs-linux-drivers_v170330.zip
3. tar jxvf linux-tbs-drivers.tar.bz2
4. cd linux-tbs-drivers
5. ./v4l/tbs-x86_64.sh
6. make -j4
7.make install
8.restart
as for 6928se it have not open source driver support
Postby wandeu » Thu Sep 17, 2020 7:56 pm
Hi I trying to install this card on ubuntu 18.04.5 but I have a error
root@iptvserver:/home/administrator/tbs17/linux-tbs-drivers# make
make -C /home/administrator/tbs17/linux-tbs-drivers/v4l
make[1]: Entering directory '/home/administrator/tbs17/linux-tbs-drivers/v4l'
make[2]: Entering directory '/home/administrator/tbs17/linux-tbs-drivers/v4l/firmware'
make[2]: Leaving directory '/home/administrator/tbs17/linux-tbs-drivers/v4l/firmware'
make -C firmware
make[2]: Nothing to be done for 'default'.
Kernel build directory is /lib/modules/5.4.0-47-generic/build
make -C /lib/modules/5.4.0-47-generic/build SUBDIRS=/home/administrator/tbs17/linux-tbs-drivers/v4l modules
make[2]: Entering directory '/usr/src/linux-headers-5.4.0-47-generic'
make[3]: *** No rule to make target 'arch/x86/tools/relocs_32.c', needed by 'arch/x86/tools/relocs_32.o'. Stop.
arch/x86/Makefile:232: recipe for target 'archscripts' failed
make[2]: *** [archscripts] Error 2
make[2]: Leaving directory '/usr/src/linux-headers-5.4.0-47-generic'
make[1]: Leaving directory '/home/administrator/tbs17/linux-tbs-drivers/v4l'
make: *** [all] Error 2
I NEED Help
Linux iptvserver 5.4.0-47-generic #51~18.04.1-Ubuntu SMP Sat Sep 5 14:35:50 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
wandeu
Postby steven » Fri Sep 18, 2020 9:39 am
[quote="wandeu"]Hi I trying to install this card on ubuntu 18.04.5 but I have a error
for kernel 5.x please use this package :
# wget http://www.tbsdtv.com/download/document/linux/media_build-2020-08-27.tar.bz2
#tar jxvf media_build-2020-08-27.tar.bz2
#cd media_build
#./install.sh
#reboot
Postby lionelbarker » Mon Nov 16, 2020 1:28 am
did you get a solution to this ?
I am on version centos 7 with kernel 3.10.0-693.21.1
I can compile on that version - but nothing later - I tried centos 8 but no joy.
I also install a free Centos 7 (3.10.0-1160.el7.x86_64) - I got your error
I have the TBS6928SE and the TBS 6220 (DVB-T/DVBT2) in my linux box and wouldn't mind being able to move forward.
Not sure if TBS are giving up on linux altogether or just for these cards
lionelbarker
Postby kingsize » Mon Nov 16, 2020 2:57 am
I too am in need of a solution for compiling on an older kernel 3.10.0-1127.19.1.el7.x86_64
/root/TBS/Closed/linux-tbs-drivers/v4l/compat.h:662:2: warning: passing argument 4 of 'snd_card_new' makes pointer from integer without a cast [enabled by default]
In file included from /root/TBS/Closed/linux-tbs-drivers/v4l/compat.h:217:0,
include/sound/core.h:237:5: note: expected 'struct module *' but argument is of type 'int'
/root/TBS/Closed/linux-tbs-drivers/v4l/compat.h:662:2: error: too few arguments to function 'snd_card_new'
include/sound/core.h:237:5: note: declared here
make[3]: *** [/root/TBS/Closed/linux-tbs-drivers/v4l/tuner-xc2028.o] Error 1
make[3]: *** [/root/TBS/Closed/linux-tbs-drivers/v4l/tda827x.o] Error 1
make[3]: *** [/root/TBS/Closed/linux-tbs-drivers/v4l/tuner-types.o] Error 1
make[3]: *** [/root/TBS/Closed/linux-tbs-drivers/v4l/tda9887.o] Error 1
make[2]: *** [_module_/root/TBS/Closed/linux-tbs-drivers/v4l] Error 2
make[2]: Leaving directory `/usr/src/kernels/3.10.0-1127.19.1.el7.x86_64'
make[1]: Leaving directory `/root/TBS/Closed/linux-tbs-drivers/v4l'
kingsize
Postby zhangchao » Mon Nov 16, 2020 10:21 am
hi ,
please add skype jack_2431 .
best regards!
zhangchao
