Help TBS 6903 conection.
Postby broncano » Wed May 15, 2019 6:26 am
Hello, is it possible to connect the TBS 6903 card to a PCI-USB adapter?
I have a laptop and I can not connect it to the motherboard as usual in normal computers.
I had thought to buy this 3 options;
Greetings.
https://www.amazon.es/3-0-PCI-Express-e ... way&sr=8-9
https://www.amazon.es/LeHang-Adaptador- ... ay&sr=8-17
https://www.amazon.es/tarjetas-adaptado ... &s=gateway
broncano
Re: Help TBS 6903 conection.
Postby steven » Wed May 15, 2019 5:01 pm
You can have a try but we are not sure whether is ok , and maybe you can have a look at our TBS5927 which is USB interface :
https://www.tbsiptv.com/tbs5927-profess ... -tuner-usb
Postby broncano » Thu May 23, 2019 8:50 am
Thanks bro.
Regards.
broncano
Postby nidhiwani » Mon Oct 14, 2019 7:15 pm
Great Information :)
nidhiwani
Return to Off topics
