tbs 2216 connection refused
Postby crews1515 » Sat May 11, 2019 10:57 am
Hello, I would like a help, as my tbs 2216 is experiencing connection problems refused when trying to enter the configuration panel, I tried to re-install the latest version of the software but without success, I would like a solution to this problem, and also I would like an older version of the software, I will leave a picture of the error it presents.Image
crews1515
Re: tbs 2216 connection refused
Postby daowei » Mon May 13, 2019 10:44 am
Please try this:
step 1: go to the TBS2216 backup pannel "encoder IP:90", access: admin/admin
step 2: download the following firmware and upgrade for it, when the upgrade finish just reboot the Encoder, then you can visite encoder pannel as normal "encoder IP" directly:
https://www.tbsiptv.com/download/tbs221 ... 170713.zip
If not work, please let me know. You can write to me "daowei@tbsdtv.com" or leave message to my Skype: daowei23lily@163.com
