TBS6522 on Ubuntu 12.04 Server
Postby Golbin » Thu May 09, 2019 4:31 pm
Hi all
Is there any driver and firmware for TBS6522 on Ubuntu 12.04 server?
Golbin
Re: TBS6522 on Ubuntu 12.04 Server
Postby steven » Thu May 09, 2019 6:30 pm
if you can update the kernel to 4.x then you can use the latest open source driver :
Postby crazycat » Fri May 10, 2019 12:15 am
For 12.04 need install 3.13 kernel (as 14.04 LTS)
https://wiki.ubuntu.com/Kernel/LTSEnabl ... e_Pangolin
And compile open-source drivers (current media_build support 3.10+ kernel with some backport limitations depend from kernel version). But most TBS cards work with 3.13 kernel (exclude old CXD2820R-based DVB-T/T2/C devices, require at least 4.4 kernel)
Postby Golbin » Sun May 12, 2019 12:12 pm
Hello again
Thank you for fast replies.
Now I'm using Ubuntu 16.04.6 server with 4.4.0-142 kernel, but there is a bug in make procedure as attached log file.
How can I solve it?
make.zip
Bug in make procedure
(5.13 KiB) Downloaded 715 times
Golbin
Postby crazycat » Mon May 13, 2019 2:42 am
update ubuntu 4.4 kernel (4.4.0-146 now) or revert last media_build commit -->
git revert fa150d8eaf8ec0afea5ef2fdd6e42c8bbe436c59
