6909X and Ubuntu 18.04.02[SOLVED]
Postby cybernet » Tue Apr 09, 2019 2:42 pm
fresh install ubuntu 18.04
latest driver install from git with the descibed procedure.
driver ok in dsmeg.
Just one sat cable on port 0 only. Port 0 connect on multiswitch with dyseqc port 1(Astra 19.2)
but dvblast cannot sync. dblast does not receive services list and stay at "frontend acquire signal"
What I have missing ?
thanks
Armand
dvblast -f 11347000 -s 22000000 -m psk_8 -v 13 -a 0 -S 1 -5 DVBS2
DVBlast 3.4 (release)
warning: restarting
debug: compiled with DVB API version 5.10
debug: using DVB API version 5.11
debug: Frontend "TurboSight TBS 6909x (Octa DVB-S/S2/S2X)" supports:
debug: frequency min: 950000, max: 2150000, stepsize: 0, tolerance: 0
debug: symbolrate min: 100000, max: 520000000, tolerance: 0
debug: capabilities:
debug: INVERSION_AUTO
debug: FEC_AUTO
debug: QPSK
debug: 2G_MODULATION
debug: MULTISTREAM
debug: delivery systems:
debug: DVBS
debug: DVBS2
debug: DSS
debug: frequency 11347000 is in Ku-band (lower)
debug: configuring LNB to v=13 p=0 satnum=0 uncommitted=0 lnb-type=universal bis_frequency=1597000
debug: tuning DVB-S frontend to f=11347000 srate=22000000 inversion=-1 fec=999 rolloff=35 modulation=psk_8 pilot=-1 mis=0 /pls-mode: ROOT (0) pls-code: 0 is-id: 0 /
warning: failed opening CAM device /dev/dvb/adapter0/ca0 (No such file or directory)
debug: setting filter on PID 0
debug: setting filter on PID 16
debug: setting filter on PID 17
debug: setting filter on PID 18
debug: setting filter on PID 19
debug: setting filter on PID 20
error: no config file
debug: frontend has acquired signal
cybernet
Re: 6909X and Ubuntu 18.04.2
Postby cybernet » Thu Apr 11, 2019 12:07 am
Found the problem.
due a lake of the guide of 6909X.
this is not mxl58.conf file for module but stid135.conf
options stid135 mode=1
Please TBS update your guide, we can win a lot of time.
thanks
cybernet
